주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 Sport Motherboard Replacement
필요한 것
  1. Samsung Galaxy S5 Sport Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Samsung Galaxy S5 Sport Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Samsung Galaxy S5 Sport Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Motherboard Replacement: 2 단계, 이미지 1/3 Samsung Galaxy S5 Sport Motherboard Replacement: 2 단계, 이미지 2/3 Samsung Galaxy S5 Sport Motherboard Replacement: 2 단계, 이미지 3/3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Motherboard Replacement, Screen: 3 단계, 이미지 1/3 Samsung Galaxy S5 Sport Motherboard Replacement, Screen: 3 단계, 이미지 2/3 Samsung Galaxy S5 Sport Motherboard Replacement, Screen: 3 단계, 이미지 3/3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy S5 Sport Motherboard Replacement: 4 단계, 이미지 2/2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  5. Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: 5 단계, 이미지 1/3 Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: 5 단계, 이미지 2/3 Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: 5 단계, 이미지 3/3
    • Remove the screws around the plate
  6. Samsung Galaxy S5 Sport Motherboard Replacement: 6 단계, 이미지 1/3 Samsung Galaxy S5 Sport Motherboard Replacement: 6 단계, 이미지 2/3 Samsung Galaxy S5 Sport Motherboard Replacement: 6 단계, 이미지 3/3
    • Push the plate out by applying pressure to the battery cavity.
  7. Samsung Galaxy S5 Sport Motherboard Replacement: 7 단계, 이미지 1/3 Samsung Galaxy S5 Sport Motherboard Replacement: 7 단계, 이미지 2/3 Samsung Galaxy S5 Sport Motherboard Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
  8. Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: 8 단계, 이미지 1/3 Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: 8 단계, 이미지 2/3 Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: 8 단계, 이미지 3/3
  9. Samsung Galaxy S5 Sport Motherboard Replacement: 9 단계, 이미지 1/2 Samsung Galaxy S5 Sport Motherboard Replacement: 9 단계, 이미지 2/2
    • Detach the pink and white wires by pulling gently on the metallic caps that connect them to the motherboard.
  10. Samsung Galaxy S5 Sport Motherboard Replacement: 10 단계, 이미지 1/2 Samsung Galaxy S5 Sport Motherboard Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the black connector above the wires by pulling straight up with tweezers.
  11. Samsung Galaxy S5 Sport Motherboard Replacement: 11 단계, 이미지 1/3 Samsung Galaxy S5 Sport Motherboard Replacement: 11 단계, 이미지 2/3 Samsung Galaxy S5 Sport Motherboard Replacement: 11 단계, 이미지 3/3
    • Pull the motherboard out. It should lift easily out of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Caroline Janiszewski
회원 가입일: 02/24/16
528 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-6, Leahy Spring 2016 USF Tampa, Team 1-6, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 22
전체 시간: 1,578
