소개
This guide will show someone how to safely remove the motherboard from the device. It is rather easy to do after the front screen and the plate underneath it are removed.
Note: In order to replace the motherboard, you will have to remove the screen. Because this is a waterproof phone the screen will most likely break during its removal. Be prepared to have to replace the screen as well.
필요한 것
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
다른 한 분이 해당 안내서를 완성하였습니다.
