이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the back casing of the phone using the notch located at the top.
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
Detach the pink and white wires by pulling gently on the metallic caps that connect them to the motherboard.
Remove the black connector above the wires by pulling straight up with tweezers.
다른 한 분이 해당 안내서를 완성하였습니다.
