주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 Sport Rear Camera Replacement
필요한 것
  1. Samsung Galaxy S5 Sport Rear Camera Replacement, Battery: 1 단계, 이미지 1/3 Samsung Galaxy S5 Sport Rear Camera Replacement, Battery: 1 단계, 이미지 2/3 Samsung Galaxy S5 Sport Rear Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Rear Camera Replacement: 2 단계, 이미지 1/3 Samsung Galaxy S5 Sport Rear Camera Replacement: 2 단계, 이미지 2/3 Samsung Galaxy S5 Sport Rear Camera Replacement: 2 단계, 이미지 3/3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Rear Camera Replacement, Screen: 3 단계, 이미지 1/3 Samsung Galaxy S5 Sport Rear Camera Replacement, Screen: 3 단계, 이미지 2/3 Samsung Galaxy S5 Sport Rear Camera Replacement, Screen: 3 단계, 이미지 3/3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Rear Camera Replacement: 4 단계, 이미지 1/2 Samsung Galaxy S5 Sport Rear Camera Replacement: 4 단계, 이미지 2/2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  5. Samsung Galaxy S5 Sport Rear Camera Replacement, Rear Camera: 5 단계, 이미지 1/3 Samsung Galaxy S5 Sport Rear Camera Replacement, Rear Camera: 5 단계, 이미지 2/3 Samsung Galaxy S5 Sport Rear Camera Replacement, Rear Camera: 5 단계, 이미지 3/3
    • Remove the seventeen screws around the plate.
  6. Samsung Galaxy S5 Sport Rear Camera Replacement: 6 단계, 이미지 1/3 Samsung Galaxy S5 Sport Rear Camera Replacement: 6 단계, 이미지 2/3 Samsung Galaxy S5 Sport Rear Camera Replacement: 6 단계, 이미지 3/3
    • Push the plate out by applying pressure to the battery cavity.
  7. Samsung Galaxy S5 Sport Rear Camera Replacement: 7 단계, 이미지 1/2 Samsung Galaxy S5 Sport Rear Camera Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the back facing camera from the top of the phone by first disconnecting the ribbon cable from the connector with a spudger or tweezers.
    • Apply delicate pressure.
결론
Samantha McGilvray
회원 가입일: 02/24/16
162 평판
안내서 1개 작성함
USF Tampa, Team 1-6, Leahy Spring 2016 USF Tampa, Team 1-6, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 746
