소개
This guide will show someone how to remove the screen from the phone. It does require several specialized tools, but the actual removal of the screen is relatively simple. However, because this is a waterproof device, removing the screen on this device WILL break the screen and make it unusable. Before beginning the removal process, be sure that you have a replacement screen.
필요한 것
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
다른 4명이 해당 안내서를 완성하였습니다.
