주요 콘텐츠로 건너뛰기
Samsung Galaxy S6 Active Power Button Replacement
필요한 것
  1. Samsung Galaxy S6 Active Power Button Replacement, SIM Card: 1 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement, SIM Card: 1 단계, 이미지 2개 중 2개
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: 3 단계, 이미지 3개 중 1개 Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: 3 단계, 이미지 3개 중 2개 Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: 3 단계, 이미지 3개 중 3개
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active Power Button Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 5 단계, 이미지 2개 중 2개
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active Power Button Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy S6 Active Power Button Replacement: 6 단계, 이미지 3개 중 3개
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active Power Button Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active Power Button Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy S6 Active Power Button Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active Power Button Replacement: 9 단계, 이미지 1개 중 1개
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active Power Button Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the display assembly (LCD and Digitizer).
  11. Samsung Galaxy S6 Active Power Button Replacement, Battery: 11 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement, Battery: 11 단계, 이미지 2개 중 2개
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
  12. Samsung Galaxy S6 Active Power Button Replacement: 12 단계, 이미지 1개 중 1개
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active Power Button Replacement: 13 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 13 단계, 이미지 2개 중 2개
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active Power Button Replacement: 14 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
  15. Samsung Galaxy S6 Active Power Button Replacement: 15 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the battery from the frame.
  16. Samsung Galaxy S6 Active Power Button Replacement, Motherboard: 16 단계, 이미지 3개 중 1개 Samsung Galaxy S6 Active Power Button Replacement, Motherboard: 16 단계, 이미지 3개 중 2개 Samsung Galaxy S6 Active Power Button Replacement, Motherboard: 16 단계, 이미지 3개 중 3개
    • Use a plastic tool to undo all the connections in the motherboard.
    • There are three connections that have to be removed.
  17. Samsung Galaxy S6 Active Power Button Replacement: 17 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 17 단계, 이미지 2개 중 2개
    • Insert the flats end of the spudger below the motherboard and twist it to pry the board up.
  18. Samsung Galaxy S6 Active Power Button Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the motherboard from the rear case.
  19. Samsung Galaxy S6 Active Power Button Replacement, Power Button: 19 단계, 이미지 1개 중 1개
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate it from the plastic cover.
  20. Samsung Galaxy S6 Active Power Button Replacement: 20 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 20 단계, 이미지 2개 중 2개
    • Once you see a large enough gap, insert a plastic tool between the frame and the plastic cover and slide it around the phone to separate both components.
  21. Samsung Galaxy S6 Active Power Button Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the plastic cover from the phone.
  22. Samsung Galaxy S6 Active Power Button Replacement: 22 단계, 이미지 1개 중 1개
    • Insert a plastic tool between the frame of the phone and the back cover at the top left corner.
  23. Samsung Galaxy S6 Active Power Button Replacement: 23 단계, 이미지 1개 중 1개
    • Leave the plastic tool inside in order to access the power button connection.
  24. Samsung Galaxy S6 Active Power Button Replacement: 24 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 24 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to pry up the power button ribbon cable until the only thing attached to the frame are the contacts.
    • Pulling too hard can rip off the ribbon cable. Make sure not to pull the entire body together.
  25. Samsung Galaxy S6 Active Power Button Replacement: 25 단계, 이미지 2개 중 1개 Samsung Galaxy S6 Active Power Button Replacement: 25 단계, 이미지 2개 중 2개
    • Insert the tweezers under the contact points to undo the connection.
  26. Samsung Galaxy S6 Active Power Button Replacement: 26 단계, 이미지 1개 중 1개
    • Use the tweezers to remove the power button bracket.
  27. Samsung Galaxy S6 Active Power Button Replacement: 27 단계, 이미지 1개 중 1개
    • The power button is located on the plastic cover.
    • Use the tweezers to push the power button out of the frame.
  28. Samsung Galaxy S6 Active Power Button Replacement: 28 단계, 이미지 1개 중 1개
    • Remove the power button from the frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lucia Valbuena
회원 가입일: 02/15/17
2,511 평판
안내서 8개를 작성함
USF Tampa, Team 1-5, Sullivan Spring 2017 USF Tampa, Team 1-5, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G5
3 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 30
전체 시간: 1,501
