주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide will demonstrate the steps necessary to replace a defective or damaged charging port daughterboard in the Samsung Galaxy S6. This component includes the audio jack, charging port, and side buttons.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
  1. Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone. Do not insert the tool into the microphone hole or you could cause damage. Look for the outline of the SIM tray. Press to eject the SIM card tray.
    • Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
    • Do not insert the tool into the microphone hole or you could cause damage. Look for the outline of the SIM tray.
    • Press to eject the SIM card tray.
    • Remove the SIM card tray from the phone.
    First thankful sir that you have a good idea for people to creat like this.. I am very happy from your website its too good. All things i learn from your website thank you..
    Lovely Khan - 답글
  2. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    which temperature must be used for heating? Thx
    fbarletta - 답글
    I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
    By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
    Fredrik -
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 답글
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 답글
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 답글
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 답글
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 답글
    Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
    Esmond Pitt - 답글
    My microwave just died, can i heat it with boiled water?
    Alex COLOMBANI - 답글
    Taping as shown is impractical when using hair dryer method—tape simply comes off in the heat and gets in way of getting out the shards on the sides. If the thing wasn’t shattered, then taping unnecessary.
    B. A. Computer Services - 답글
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - 답글
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - 답글
    The “Galaxy S8 Replacement Battery” that you are selling with the kit is the wrong battery, the one that you are selling is a 3000mAh (which is the wrong amperage) as the OEM Samsung Galaxy S8 battery is “Model #: EB-BG892ABA / 4000mAh / Normal Voltage: 3.85V / Charge Voltage: 4.4V / A/S: 1588-3366 4000mAh 15.0Wh
    stevengenat - 답글
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - 답글
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - 답글
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - 답글
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - 답글
    I’ve tried for 2 days and cannot get this to work. I should have just taken it to my local iphone fixit shop. This is a frustrating purchase to say the least.
    jeffrey hill - 답글
    Step 1 should be: now that you have looked over the tools of this repair kit, take your ipad to the nearest repair store and let them handle it. Sure you will waste about $65 by purchasing this kit and the cost of the repair but you will not tear your ipad up and you will have at least 2 days of your life that you can spend time with your family.
    jeffrey hill - 답글
  3. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
    yamayhuang - 답글
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 답글
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 답글
    I don't own a microwave.
    mdanihy - 답글
    Its again waterproof when you change iphone 7 battery?
    Jon - 답글
    I don't have a microwave???
    Joe Blow - 답글
    30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
    Sam Stieg - 답글
    can i use just ordinary microwave???
    juneseok kwon - 답글
    If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
    Mohideen Rifay - 답글
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 답글
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 답글
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 답글
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 답글
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 답글
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 답글
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - 답글
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - 답글
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - 답글
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - 답글
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - 답글
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Rapp -
  4. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Will a hair dryer work for heating the glass?
    Me berg - 답글
    Can you use an oven instead?
    Rafael -
    Yes, as does a heat gun.
    anonymous 4602 - 답글
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 답글
    microwave on WHAT WATTAGE ??? 100 W OR 1600 W ??? NOT THE SAME
    Ivor Pocrnja - 답글
  5. Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive. If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
    • Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • Shift the iOpener to heat the remaining section of the panel for another two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    are there any option out there that allows you to heat the adhesive outdoors without any power plug?
    Brotan Store - 답글
    There's a star in the center of our solar system, you could try that.
    John Joiner -
    the way we do it at Get it fixed cellphone repair calgary is with a heat gun, wich is way easier than this, make sure to wear some gloves and dont worry to use to much heat as long as you point just to the back of the phone, (the back panel is thick enough to protect the logic board from over heat) instead of the usual blue plastic piece i sugest to use the thinnest metal razor knife and a business card so you can insert the business card and move it all around the frame, those blue plastic things are way too thick that will break the glass panel if you apply to much pressure
    get it fixed - 답글
    After did that with my own heat pad, the white paint got ripped off but luckily glass back cover did not break. So I scratched all white part of the back cover and now its all transparent.
    Jae Chung - 답글
    I used a purpose built heating device at 100 degree celsius. Lower temperatures didn't work.
    ken - 답글
    I used a blow dryer, attached my multimeter heat sensor to the back to monitor the temperature. At 54 degrees Celsius I could separate the back with a suction cup from my phone without damaging the paint.
    LRD - 답글
    I gave up on the hot bag after 4 heat and apply cycles. I was only getting the back up to 60c using an infrared thermometer. I switched to a harbor freight 1500w heat gun set to Low, moving constantly around the back, until the back read 95c. The back came off easily at that point.
    Nathan Wray - 답글
    using a blowtorch on low heart for 3-5 seconds at close range also works
    Achi Namaratne - 답글
    I found another site that said temps of 203F/95C were required to soften the glues. Once I started using those temps with my heat gun, as well as a tool I made by just cutting the flat front/back panel from a package of screws (any plastic package that has a flat panel will work) , I had the back off in no time. Had I continued to use the plastic pick shown in the instructions, I really doubt I would have gotten the back off since I couldn’t get enough force on the back from my suction cup. The thin package plastic acted almost like a knife as I moved it around the outside edge. WARNING: If you have to reheat the back, REMOVE THE PACKAGE PLASTIC!! It will start to melt from the heat of a heat gun. Good Luck!!
    morttormjch - 답글
    I gave up after struggling 1 hour with an hairdryer, the glass was around 65°C and it doesn't wants to lift up at all, anybody got tips ?
    123321mario - 답글
    What tools are you using Mario?
    vazersecurity -
  6. Once the rear glass is hot to the touch, apply a suction cup near the bottom edge  of the glass. Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap. Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
    • Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
    • Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
    • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
    If the rear screen is cracked/smashed, you will not be able to use a suction cup to remove it. The suction could would not seal because of the cracks. I tried masking tape, 3M shiny HVAC tape, and others, and the suction could would not seal to those surfaces either.
    I ended up using the sharp point of the smudger to remove some shards of glass to get underneath the cover to leverage it up and out. Definitely use gloves and safety glasses if you have to do this.
    dougpender - 답글
    Thank you for your comment. I needed to see this particular instance of what to do when the back cover was cracked. I was going to try to suction it with tape covering it. This saved me some heartache. You're an angel!!
    Jessie Brooks -
    Be careful during this step- reapply heat before attempting this one (battery issues tend to melt internal “areas” ) and this area is most prone to crack during the lifting of the back plate.
    Briannah - 답글
    J’ai utilisé la même ventouse.
    En soulevant la poignée rabattable, la simple succion a aspiré un disque de verre ! J’ai brisé la vitre sans même tirer…
    pierre brunet - 답글
    I think it is just about impossible to do this without at least removing some paint on the edges. Order a new back before you attempt this. It has the adhesive already on it and costs less than $10 on eBay.
    Thomas Hayes - 답글
    In order to get in more easily, I normally use the iFlex (the metal one) which is thin enough to create a little space, and then i insert a thinner plastic sheet, just like the default screen protector you might find on some huawei or xiaomi phones. That plus half a drop of alcohol should do the trick. Use caution and be very patient.
    Stefano Restuccia - 답글
  7. Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass. Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    • Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
    • Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    • Re-heat the rear glass as needed to prevent the glue from cooling and hardening.
    Be careful that the bottom of the phone is well heated, and add a drop or so of isopropyl alcohol. When I removed the back glass of my S6, some of the black coating on the glass stayed stuck to the adhesive, so to return my phone to its original appearance, I’ll have to get a new back glass.
    Gary F - 답글
  8. Repeat the heating and cutting procedure for the remaining three sides of the phone. Leave an opening pick under each edge to prevent the adhesive from resealing. Leave an opening pick under each edge to prevent the adhesive from resealing.
    • Repeat the heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick under each edge to prevent the adhesive from resealing.
    At this stage I didn’t use a plastic pick as I think they are too thick and will crack a screen that’s not already cracked. I used a stainless steel
    I sesame blade which does a much better job of cutting through the adhesive. Just be careful not to insert it in too far. I sometimes put a mark on my blade to ensure it doesn’t go in too far.
    Wayne Lyell - 답글
    I used a card like the ones people use to play poker or any card game with. Only one was needed to separate the back without any damage to the paint.
    LRD - 답글
    Be sure to apply a decent amount of heat when removing the last bit of the rear glass, cracked the rear of my screen (only a small amount mind) trying too use too much force not enough heat for the last spot.
    spank2103 - 답글
  9. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  10. Use an opening pick to slice through any remaining adhesive. Remove the rear glass.
    • Use an opening pick to slice through any remaining adhesive.
    • Remove the rear glass.
    The rear glass is very fragile. I cracked mine across the camera opening while cleaning off the old sealant. Next time ( I will have to order one and do it again…doh) I’ll place it on a flat surface while cleaning it.
    Greg Scott - 답글
    This is also a really good time to remove the SIM tray
    John Murphy - 답글
  11. To install new rear glass: Use tweezers to peel away any remaining adhesive from the phone's chassis.
    • To install new rear glass:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • If you're reinstalling the old rear glass, or using rear glass without adhesive pre-installed, follow this guide.
    You should note that the adhesive strip may need to be fully removed from the frame in order to proceed with repairs. The adhesive on my phone covered all of the screws exposed in the next step.
    Sean Cruz - 답글
    When I did my battery, the adhesive stayed almost 100% on the back glass and was still in good shape. What didn’t remain attached only lifted slightly and I was able to coax it back to its original location with tweezers. I didn’t bother to remove and replace the adhesive layer because mine was still good. I set the glass out of the way where it wouldn’t get dirt on the adhesive while I finished the battery swap. I added some additional heat (hair dryer) after reattaching the glass to make sure the adhesive made the best seal.
    Wayne Thomason - 답글
  12. Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
    • Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
    Do yall sell the screws and the screw organization mat
    The lit asf Channel - 답글
  13. Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone. Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone. Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone.
    • Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone.
  14. Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard. Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
    • Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
    Hello ! Is there a way i can buy only this flex cord that you are showing . A GSM service broke it and wont fix my phone
    Lica Mihai-Alexandru - 답글
  15. Disconnect the home button ribbon cable from the motherboard. Disconnect the home button ribbon cable from the motherboard.
    • Disconnect the home button ribbon cable from the motherboard.
  16. Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard. Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard. Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
    • Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
  17. Disconnect the display ribbon cable from the motherboard using the flat end of the spudger. Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
    • Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
  18. Disconnect the earpiece ribbon cable from the motherboard. Disconnect the earpiece ribbon cable from the motherboard.
    • Disconnect the earpiece ribbon cable from the motherboard.
  19. The motherboard is an ESD sensitive component and should be handled with care. iFixit recommends using a anti-static bracelet whenever handling components of this nature to avoid damage. Grip the motherboard on both edges toward the top of the device.
    • The motherboard is an ESD sensitive component and should be handled with care. iFixit recommends using a anti-static bracelet whenever handling components of this nature to avoid damage.
    • Grip the motherboard on both edges toward the top of the device.
    • Do not lift the motherboard all the way out in this step; the ribbon cable on the underside needs to be disconnected first.
    • Lift the motherboard up and away from the display, taking care not to put too much stress on the daughterboard ribbon cable.
    Better to remove the antenna connector from daughter board and keep the connector on main board, as You will planning to remove it you will need to take from it anyway.
    Gabriel Pinho - 답글
  20. Disconnect the daughterboard ribbon cable from the underside of the motherboard. Disconnect the daughterboard ribbon cable from the underside of the motherboard.
    • Disconnect the daughterboard ribbon cable from the underside of the motherboard.
    I had trouble removing the daughter board connector so I gently folded the main board back and was able to remove the battery.
    Eric Bornstein - 답글
  21. Remove the two 2.5mm Phillips #00 screws.
    • Remove the two 2.5mm Phillips #00 screws.
  22. Using the pointed end of spudger, pry up the small section of daughterboard secured with a light adhesive. Using the pointed end of spudger, pry up the small section of daughterboard secured with a light adhesive.
    • Using the pointed end of spudger, pry up the small section of daughterboard secured with a light adhesive.
  23. Lift the daughterboard up and away from the body of the phone to remove it. Lift the daughterboard up and away from the body of the phone to remove it. Lift the daughterboard up and away from the body of the phone to remove it.
    • Lift the daughterboard up and away from the body of the phone to remove it.
    I think this step needs to add the need to carefully remove the soft key contacts? That’s where I’ve come unstuck :(
    Simone Casey - 답글
결론
To reassemble your device, follow these instructions in reverse order. Follow this guide to reinstall the rear glass.
다른 64명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 2012년 10월 18일
401,260 평판
안내서 547개 작성하였습니다
iFixit iFixit 회원
Community
111 회원들
안내서 10,673개 작성하였습니다
quick question, s6 edge charging port G925i is it compatible with G925F.
George - 답글
I was able to follow these directions to replace the daughter-board on my Galaxy s6. I have *NO* technical experience. The real difficulty was with the products from iFixit - the gel pad didn’t melt the adhesive (I used a heat gun instead), the “guitar pics” were too flimsy & the screwdriver was RIDICULOUSLY small…I bought a mini Craftsman set that made ALL the difference.
Jamie - 답글
hey i need to get the version for Samsung s6 edge t mobile the whole charging system
the version G925i or G925F or which one and where can i ship it from?
jamal - 답글
My Samsung charging cable was melted, and after this I could not charge phone using micro usb. I’ve replaced Charging Port Daughterboard, but after this there is no Fast Charge. This option turned On in setup, but phone charging +4h.
Charger replaced, usb cable with 5 pins.
Any issue?
Qba PL - 답글
I reqested a new daughterboard for Samsung galaxy s6 edge. I received a daughter board that does not match quite right. The original has a SM -0925v sub USB. The daughterboard I received has a SM- 0928V SUB USB. it does not fit.
Kathy Carkhuff - 답글
Hi.
Can we use g925f model charging board in g925i ?
sidhaan9 - 답글
On reassembly don't forget to move the Bluetooth and sell antenna over to the new daughter board
Steven Williams - 답글
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 161
30일 전: 856
전체 시간: 56,719
