이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
냄비나 팬에 iOpener가 완전히 잠길 정도로 충분한 물을 채우세요.
물이 끓을 때까지 가열하세요. 불을 끄세요.
iOpener를 뜨거운 물에 2~3분간 담그세요. iOpener가 물에 완전히 잠겼는지 확인합니다.
집게를 사용하여 뜨거운 물에서 가열된 아이오페너를 꺼내세요.
수건으로 iOpener를 완전히 말리세요.
iOpener를 사용할 준비가 되었습니다! iOpener를 재가열해야 한다면 물을 끓인 후 불을 끄고 2~3분 동안 iOpener를 물에 담가 두세요.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Repeat the heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick under each edge to prevent the adhesive from resealing.
Use an opening pick to slice through any remaining adhesive.
Remove the rear glass.
이 단계에 사용된 도구:Tweezers$4.99-
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone.
Use a spudger to disconnect the front facing camera from the motherboard.
Remove the front facing camera.
다른 4명이 해당 안내서를 완성하였습니다.
