이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
Grip the motherboard on both edges toward the top of the device.
Lift the motherboard up and away from the display, taking care not to put too much stress on the daughterboard ribbon cable.
Disconnect the daughterboard ribbon cable from the underside of the motherboard.
