주요 콘텐츠로 건너뛰기
Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement
필요한 것
  1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: 1 단계, 이미지 1/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: 1 단계, 이미지 2/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: 1 단계, 이미지 3/3
    • Peel the clear film off of the adhesive packaging.
  2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 2 단계, 이미지 1/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 2 단계, 이미지 2/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 2 단계, 이미지 3/3
    • Lay the glass panel face-up and rotate it so that the lens holes are on your right.
    • Grasp the adhesive from both sides and align the tape over the rear glass.
    • Make sure to align the camera and heart rate sensor holes on the phone with the adhesive tape.
    • Lay the adhesive on top of the glass.
  3. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 3 단계, 이미지 1/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 3 단계, 이미지 2/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 3 단계, 이미지 3/3
    • Run your fingers over the tape to firmly attach it to the glass.
  4. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 4 단계, 이미지 1/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 4 단계, 이미지 2/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 4 단계, 이미지 3/3
    • Peel back the outer layer of green film.
  5. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 5 단계, 이미지 1/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 5 단계, 이미지 2/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 5 단계, 이미지 3/3
    • Peel back the inner film layer.
  6. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 6 단계, 이미지 1/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 6 단계, 이미지 2/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 6 단계, 이미지 3/3
    • If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
    • This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over.
  7. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 7 단계, 이미지 1/2 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 7 단계, 이미지 2/2
    • Use a pair of tweezers to remove any adhesive still on the midframe.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth.
  8. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 8 단계, 이미지 1/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 8 단계, 이미지 2/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 8 단계, 이미지 3/3
    • Align the top of the rear glass with the top of the phone.
    • Press the top edge of the glass into the midframe so that there's no gap at the top.
  9. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 9 단계, 이미지 1/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 9 단계, 이미지 2/3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 9 단계, 이미지 3/3
    • Lower the rest of the rear panel and press it firmly into the midframe.
결승점
다른 81명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,762 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 3개
Where do you by the adhesive strip for the repair
Nico Velasquez - 답글
There are a lot of places like replacebase
Allspares,and a lot other but usually the back glass comes with the adhesive on
Alkinos vasiliou -
How strong is the s6 edge plus rear glass are they known to break easy.
Aaron c - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 56
전체 시간: 33,971
