이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Grasp the adhesive from both sides and align the tape over the rear glass.
Lay the adhesive on top of the glass.
If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
Use a pair of tweezers to remove any adhesive still on the midframe.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth.
Align the top of the rear glass with the top of the phone.
Press the top edge of the glass into the midframe so that there's no gap at the top.
Lower the rest of the rear panel and press it firmly into the midframe.
다른 81명이 해당 안내서를 완성하였습니다.
댓글 3개
Where do you by the adhesive strip for the repair
There are a lot of places like replacebase
Allspares,and a lot other but usually the back glass comes with the adhesive on
