주요 콘텐츠로 건너뛰기
Samsung Galaxy S6 Home Button Replacement
필요한 것
  1. Samsung Galaxy S6 Home Button Replacement, SIM Card: 1 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement, SIM Card: 1 단계, 이미지 2/2
    • Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
    • Press to eject the SIM card tray.
    • Don't press too hard or you may damage the SIM card tray.
  2. Samsung Galaxy S6 Home Button Replacement: 2 단계, 이미지 1/1
    • Remove the SIM card tray from the phone.
  3. Samsung Galaxy S6 Home Button Replacement, iOpener Heating: 3 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement, iOpener Heating: 3 단계, 이미지 2/2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  4. Samsung Galaxy S6 Home Button Replacement: 4 단계, 이미지 1/1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  5. Samsung Galaxy S6 Home Button Replacement: 5 단계, 이미지 1/1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  6. Samsung Galaxy S6 Home Button Replacement, Alternate iOpener heating method: 6 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement, Alternate iOpener heating method: 6 단계, 이미지 2/2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  7. Samsung Galaxy S6 Home Button Replacement, Rear Glass: 7 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement, Rear Glass: 7 단계, 이미지 2/2
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
    • Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • Shift the iOpener to heat the remaining section of the panel for another two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  8. Samsung Galaxy S6 Home Button Replacement: 8 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 8 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 8 단계, 이미지 3/3
    • Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
    • Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
    • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
  9. Samsung Galaxy S6 Home Button Replacement: 9 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 9 단계, 이미지 2/2
    • Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
    • Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    • Re-heat the rear glass as needed to prevent the glue from cooling and hardening.
  10. Samsung Galaxy S6 Home Button Replacement: 10 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 10 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 10 단계, 이미지 3/3
    • Repeat the heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick under each edge to prevent the adhesive from resealing.
  11. Samsung Galaxy S6 Home Button Replacement: 11 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 11 단계, 이미지 2/2
    • Use an opening pick to slice through any remaining adhesive.
    • Remove the rear glass.
  12. Samsung Galaxy S6 Home Button Replacement: 12 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 12 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • To install new rear glass:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • If you're reinstalling the old rear glass, or using rear glass without adhesive pre-installed, follow this guide.
  13. Samsung Galaxy S6 Home Button Replacement, Midframe Assembly: 13 단계, 이미지 1/1
    • Remove the thirteen 3.5mm Phillips #00 screws securing the midframe to the phone.
  14. Samsung Galaxy S6 Home Button Replacement: 14 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 14 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 14 단계, 이미지 3/3
    • Before you perform this step, make sure you've ejected the SIM card tray.
    • Firmly grasp the edge of the midframe assembly.
    • Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
    • While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
    • Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
    • Be careful not to accidentally insert the opening pick between the glass and display.
    • To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
    • You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
  15. Samsung Galaxy S6 Home Button Replacement: 15 단계, 이미지 1/1
    • Lift the midframe assembly up to separate it from the rest of the phone.
  16. Samsung Galaxy S6 Home Button Replacement, Disassembling Samsung Galaxy S6 Battery Connector: 16 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement, Disassembling Samsung Galaxy S6 Battery Connector: 16 단계, 이미지 2/2
    • Use the flat end of the spudger to disconnect the battery connector from its socket on the motherboard.
  17. Samsung Galaxy S6 Home Button Replacement, Motherboard Assembly: 17 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement, Motherboard Assembly: 17 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement, Motherboard Assembly: 17 단계, 이미지 3/3
    • Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
  18. Samsung Galaxy S6 Home Button Replacement: 18 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 18 단계, 이미지 2/2
    • Use the flat end of the spudger to disconnect the home button connector.
  19. Samsung Galaxy S6 Home Button Replacement: 19 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 19 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
  20. Samsung Galaxy S6 Home Button Replacement: 20 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 20 단계, 이미지 2/2
    • Disconnect the earpiece speaker assembly cable connector from the motherboard.
  21. Samsung Galaxy S6 Home Button Replacement: 21 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 21 단계, 이미지 2/2
    • Lift the camera-side end of the motherboard to separate it from the display frame.
    • You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
    • Do not fully remove the motherboard yet—it is still attached to the daughterboard via a ribbon cable on the underside of the motherboard.
  22. Samsung Galaxy S6 Home Button Replacement: 22 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 22 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
  23. Samsung Galaxy S6 Home Button Replacement, Screen: 23 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement, Screen: 23 단계, 이미지 2/2
    • If your display glass is badly cracked, tape over the glass to contain stray glass and make prying easier.
    • Reheat the iOpener.
    • Lay the iOpener across the S6 display. After two minutes, shift the iOpener to the other half of the screen.
  24. Samsung Galaxy S6 Home Button Replacement: 24 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 24 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 24 단계, 이미지 3/3
    • Insert the opening pick in the battery-side edge of the phone, between the frame and display, at an upward angle.
    • When done correctly, you will see a gap between the display frame and the display assembly.
    • When done incorrectly, the pick will be visible through the glass. If this happens simply remove the pick and start again.
  25. Samsung Galaxy S6 Home Button Replacement: 25 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 25 단계, 이미지 2/2
    • Slide the pick down the edge of the display to separate the adhesive underneath.
    • Stop cutting when you get to the daughterboard to avoid the delicate capacitive button under the display.
    • If cutting becomes difficult at any point, reheat and reapply the iOpener.
    • After cutting the adhesive, leave the pick in the side of the display to prevent the display from re-adhering to the frame.
  26. Samsung Galaxy S6 Home Button Replacement: 26 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 26 단계, 이미지 2/2
    • Slide the pick along the bottom edge of the phone, from the headphone jack to just past the charging port.
    • Do not insert the opening pick more than 0.25 inches (~6mm) to avoid damaging the home button.
  27. Samsung Galaxy S6 Home Button Replacement: 27 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 27 단계, 이미지 2/2
    • Insert an opening pick about 0.5 inches (~12mm) under the bottom corner of the display, near the headphone jack.
    • Keep a close eye on the button's ribbon cable as you insert the pick. The cable is fragile and very easy to tear. If the pick is hard to insert or the cable starts to stretch, apply more heat.
    • Leave the pick under the display to prevent the button from re-adhering to the display.
    • If you do break either of the capacitive buttons or ribbon cables, you can replace the daughterboard assembly, which includes new capacitive buttons.
  28. Samsung Galaxy S6 Home Button Replacement: 28 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 28 단계, 이미지 2/2
    • Insert an opening pick about 0.5 inches (~12mm) under the opposite bottom corner of the display.
  29. Samsung Galaxy S6 Home Button Replacement: 29 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 29 단계, 이미지 2/2
    • Slide an opening pick along the side of the phone opposite the battery to separate the adhesive underneath.
  30. Samsung Galaxy S6 Home Button Replacement: 30 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 30 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 30 단계, 이미지 3/3
    • Slide a pick along the top of the phone towards the vibrator.
    • Pull the pick out slightly to avoid the earpiece speaker grille.
  31. Samsung Galaxy S6 Home Button Replacement: 31 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 31 단계, 이미지 2/2
    • Use an opening pick to gently pry the battery side of the frame away from the display.
    • If the display and frame to not separate easily, use an opening pick to cut any remaining adhesive. If cutting is difficult, reheat and reapply an iOpener.
    • Do not completely remove the display yet. The display cable is still threaded through the frame.
  32. Samsung Galaxy S6 Home Button Replacement: 32 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 32 단계, 이미지 2/2
    • Route the display's flex cable through its hole in the frame in order to fully separate the right edge of the display.
  33. Samsung Galaxy S6 Home Button Replacement: 33 단계, 이미지 1/1
    • Before installing a new display, it's very important to remove all traces of the old adhesive from the frame, while taking special care to remove any small glass fragments.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
    • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged. If necessary, replace the frame.
    • The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
  34. Samsung Galaxy S6 Home Button Replacement, Daughterboard: 34 단계, 이미지 1/1
    • Remove the single 3.0mm Phillips #00 screw securing the daughterboard to the display frame.
  35. Samsung Galaxy S6 Home Button Replacement: 35 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 35 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 35 단계, 이미지 3/3
    • Flip the display frame over so the home button is facing you.
    • Insert the pointed edge of the spudger into the groove next to the right soft button LED cable.
    • Gently lift the LED cable off the display frame.
    • Be careful to not rip these delicate cables when peeling them off the plastic frame.
  36. Samsung Galaxy S6 Home Button Replacement: 36 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 36 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 36 단계, 이미지 3/3
    • Insert the pointed edge of the spudger into the groove above the left soft button LED cable.
    • Lift the left soft button LED cable off the plastic frame.
  37. Samsung Galaxy S6 Home Button Replacement: 37 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 37 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 37 단계, 이미지 3/3
    • Flip the frame over again and lift up the daughterboard to peel it off the display frame.
  38. Samsung Galaxy S6 Home Button Replacement, Home Button: 38 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement, Home Button: 38 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement, Home Button: 38 단계, 이미지 3/3
    • Orient the display frame so the home button connector faces you.
    • Use the pointed edge of the spudger to separate the home button ribbon cable from the display frame.
    • Be careful when removing the home button ribbon cable. It is delicate and can tear easily.
  39. Samsung Galaxy S6 Home Button Replacement: 39 단계, 이미지 1/2 Samsung Galaxy S6 Home Button Replacement: 39 단계, 이미지 2/2
    • Use the pointed end of a spudger to push the home button cable through the display frame.
  40. Samsung Galaxy S6 Home Button Replacement: 40 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 40 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 40 단계, 이미지 3/3
    • Flip the display frame over and use the pointed end of a spudger to pull the home button cable completely through the hole.
  41. Samsung Galaxy S6 Home Button Replacement: 41 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 41 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 41 단계, 이미지 3/3
    • Slide the spudger under the cable to continue separating it from the frame.
  42. Samsung Galaxy S6 Home Button Replacement: 42 단계, 이미지 1/3 Samsung Galaxy S6 Home Button Replacement: 42 단계, 이미지 2/3 Samsung Galaxy S6 Home Button Replacement: 42 단계, 이미지 3/3
    • The button is held in place by a tab on each side. To remove the button, it needs to move far enough over to clear the edge of the bracket.
    • Once the cable is entirely separated from the frame, use a spudger to push the home button to the far left of its bracket.
    • Use a spudger to push the home button up and out of its bracket.
  43. Samsung Galaxy S6 Home Button Replacement: 43 단계, 이미지 1/1
    • Remove the home button.
결론
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
다른 23명이 해당 안내서를 완성하였습니다.
Dante Mazzanti
회원 가입일: 07/13/15
36,222 평판
안내서 26개 작성하였습니다
댓글 6개
So it's literally the last thing you remove on the entire stinking thing /facepalm
Jakim Toomey - 답글
Can i change the fingerprint sensor? My fingerprint sensor is having a issue: "make sure the home key is clean and dry". But its so clean and so dry. Can sameone help me? Would I fix that sensor or change it to another?
Caio c - 답글
You forgot to mention how to enable the fingerprint sensor when you replace the home button. When you replace the home button the fingerprint sensor wont work. Not sure what Samsung does but it has to be a software flash to allow the new part to marry to the mother board. There are lots of how to articles and videos that are half assed and just give enough info to get you into trouble. Though I wouldnt pay Samsung $100 to replace a button, these facts should be included in the repair article. Im really surprised no one has the fix for this in the form of an APK. Ive seen lots of screen replacement videos and all are half assed that show you the wrong way to remove the screen digitizer. I ripped my home button and back buttons circuit because of idiots that post how to videos that skip these important steps. I wish I would have paid the extra $$ and had the local shop do my repair from the start. He told me that the sensor wont work after repair and so far he is correct.
GGG - 답글
I broke my display doing this :( I suggest you not to do it if you are not 100 % sure of yours skills.
Andrea Silvestro - 답글
This is such BS. there is a faster way to get to the button if you think f it. they are just trying to make it seem difficult/complex so you pay others to do it.
Jay Smith - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 64
전체 시간: 75,534
