주요 콘텐츠로 건너뛰기
Samsung Galaxy S6 Rear Glass Adhesive Replacement
필요한 것
  1. Samsung Galaxy S6 Rear Glass Adhesive Replacement, Rear Glass Adhesive: 1 단계, 이미지 1/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement, Rear Glass Adhesive: 1 단계, 이미지 2/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement, Rear Glass Adhesive: 1 단계, 이미지 3/3
    • Peel the clear film off of the adhesive packaging.
  2. Samsung Galaxy S6 Rear Glass Adhesive Replacement: 2 단계, 이미지 1/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 2 단계, 이미지 2/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 2 단계, 이미지 3/3
    • Lay the glass panel face-up and rotate it so that the lens holes are on your right.
    • Grasp the adhesive from both sides and align the tape over the rear glass.
    • Make sure to align the camera and heart rate sensor holes on the phone with the adhesive tape.
    • Lay the adhesive on top of the glass.
  3. Samsung Galaxy S6 Rear Glass Adhesive Replacement: 3 단계, 이미지 1/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 3 단계, 이미지 2/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 3 단계, 이미지 3/3
    • Run your fingers over the tape to firmly attach it to the glass.
  4. Samsung Galaxy S6 Rear Glass Adhesive Replacement: 4 단계, 이미지 1/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 4 단계, 이미지 2/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 4 단계, 이미지 3/3
    • Peel back the outer layer of green film.
  5. Samsung Galaxy S6 Rear Glass Adhesive Replacement: 5 단계, 이미지 1/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 5 단계, 이미지 2/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 5 단계, 이미지 3/3
    • Peel back the inner film layer.
  6. Samsung Galaxy S6 Rear Glass Adhesive Replacement: 6 단계, 이미지 1/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 6 단계, 이미지 2/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 6 단계, 이미지 3/3
    • If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
    • This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over.
  7. Samsung Galaxy S6 Rear Glass Adhesive Replacement: 7 단계, 이미지 1/2 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 7 단계, 이미지 2/2
    • Use a pair of tweezers to remove any adhesive still on the midframe.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth.
  8. Samsung Galaxy S6 Rear Glass Adhesive Replacement: 8 단계, 이미지 1/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 8 단계, 이미지 2/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 8 단계, 이미지 3/3
    • Align the top of the rear glass with the top of the phone.
    • Press the top edge of the glass into the midframe so that there's no gap at the top.
  9. Samsung Galaxy S6 Rear Glass Adhesive Replacement: 9 단계, 이미지 1/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 9 단계, 이미지 2/3 Samsung Galaxy S6 Rear Glass Adhesive Replacement: 9 단계, 이미지 3/3
    • Lower the rest of the rear panel and press it firmly into the midframe.
결승점
다른 141명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 02/05/15
223,424 평판
안내서 168개 작성하였습니다
댓글 9개
It would be handy to tell us a reliable place to obtain the adhesive from as iFixit doesn't appear to stock it
Rob Crawford - 답글
I snagged a replacement front and back glass adhesive and a new daughter board for the S6 from http://www.mobiledefenders.com/. They seem okay so far. Only about a buck for the adhesives, plus shipping.
PortableOpossum -
Will the adhesive for a galaxy s6 work on the back cover of an s6 edge?
shabria jones - 답글
It won't work. Size is different. One for S6 is larger
Jimmy -
Couldn't you just cut it to size? If it's just a pad of adhesive, you should be able to just cut it to the smaller backing size. I'd assume it's non conductive, but make sure it's not blocking anything important.
Ampera -
amazon has the S6 film
Richard Meyers - 답글
I ordered a rear glass housing from amazon with the adhesive pre-aligned and installed so that all I have to do is peel away the film and snap it on.
Sean Myer - 답글
While cleaning off the old adhesive the rear housing broke into 3 pieces??!! I was using a kitchen table place mat….I would have appreciated the author giving me a heads up on how fragile the rear cover is.
Walter Smith - 답글
It’s glass. That should be warning enough.
Max Powers -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 23
30일 전: 65
전체 시간: 93,052
