주요 콘텐츠로 건너뛰기
Samsung Galaxy S7 Active Battery Replacement
필요한 것
  1. Samsung Galaxy S7 Active Battery Replacement, Samsung Galaxy S7 Active Disassembly: 1 단계, 이미지 1/1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Battery Replacement: 2 단계, 이미지 1/1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy S7 Active Battery Replacement: 3 단계, 이미지 2/2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Battery Replacement: 4 단계, 이미지 1/1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Battery Replacement: 6 단계, 이미지 1/1
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Battery Replacement: 7 단계, 이미지 1/1
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Battery Replacement: 8 단계, 이미지 1/1
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Battery Replacement: 9 단계, 이미지 1/1
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Battery Replacement: 10 단계, 이미지 1/1
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Battery Replacement: 11 단계, 이미지 1/3 Samsung Galaxy S7 Active Battery Replacement: 11 단계, 이미지 2/3 Samsung Galaxy S7 Active Battery Replacement: 11 단계, 이미지 3/3
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Battery Replacement: 12 단계, 이미지 1/2 Samsung Galaxy S7 Active Battery Replacement: 12 단계, 이미지 2/2
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Alexander Yazdani
회원 가입일: 04/18/18
846 평판
안내서 3개 작성하였습니다
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G1
4 회원들
안내서 15개 작성하였습니다
댓글 3개
I would advise against using a metal spudger to remove the battery itself. While working at a device repair chain in the past, a coworker of mine punctured a battery with a metal spudger and destroyed the phone. Instead, use a sturdy plastic spudger to remove the battery. Otherwise, great guide!
Derek Margheim - 답글
I got the battery fixed but shattered my screen wish it was more informative on how to get out the screen
joshua hofer - 답글
Would using the Anti-clamp with heat gun be better option?
Kiriakos White - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 71
전체 시간: 24,533
