주요 콘텐츠로 건너뛰기
Samsung Galaxy S7 Active Disassembly
필요한 것
  1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: 1 단계, 이미지 1/1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Disassembly: 2 단계, 이미지 1/1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Disassembly: 3 단계, 이미지 1/2 Samsung Galaxy S7 Active Disassembly: 3 단계, 이미지 2/2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Disassembly: 4 단계, 이미지 1/1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Chengbin Owen Kuang
회원 가입일: 04/17/18
207 평판
안내서 1개 작성함
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G1
4 회원들
안내서 15개 작성하였습니다
댓글 한 개
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 22
전체 시간: 4,340
