주요 콘텐츠로 건너뛰기
Samsung Galaxy S7 Active Screen Replacement
필요한 것
  1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: 1 단계, 이미지 1/1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Screen Replacement: 2 단계, 이미지 1/1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Screen Replacement: 3 단계, 이미지 1/2 Samsung Galaxy S7 Active Screen Replacement: 3 단계, 이미지 2/2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Screen Replacement: 4 단계, 이미지 1/1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Screen Replacement, Screen: 5 단계, 이미지 1/3 Samsung Galaxy S7 Active Screen Replacement, Screen: 5 단계, 이미지 2/3 Samsung Galaxy S7 Active Screen Replacement, Screen: 5 단계, 이미지 3/3
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Samsung Galaxy S7 Active Screen Replacement: 6 단계, 이미지 1/3 Samsung Galaxy S7 Active Screen Replacement: 6 단계, 이미지 2/3 Samsung Galaxy S7 Active Screen Replacement: 6 단계, 이미지 3/3
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Erick Vazquez
회원 가입일: 04/18/18
180 평판
안내서 1개 작성함
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G1
4 회원들
안내서 15개 작성하였습니다
댓글 3개
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - 답글
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - 답글
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 25
전체 시간: 9,064
