주요 콘텐츠로 건너뛰기
소개
Follow this guide to replace a dead or low-capacity battery for the Samsung Galaxy S7 Edge.
Note: The curved edge and strong adhesive make the initial opening procedure very challenging. Be patient, repeat multiple heat and pull cycles, and the adhesive will eventually loosen.
Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
If your battery is swollen, take appropriate precautions. Do not heat your phone. If needed, you can use a dropper or syringe to inject isopropyl alcohol (90+%) around the edges of the back cover to weaken the adhesive. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
  1. Samsung Galaxy S7 Edge Battery Replacement, Rear Glass: 1 단계, 이미지 1/1
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Heat an iOpener and apply it to a long edge of the phone for about two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S7 Edge Battery Replacement: 2 단계, 이미지 1/1
    • Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not adhere well on the curved portion of the glass.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift on the suction cup and insert an opening pick under the rear glass.
    • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
  3. Samsung Galaxy S7 Edge Battery Replacement: 3 단계, 이미지 1/1
    • Once you have the pick firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
  4. Samsung Galaxy S7 Edge Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy S7 Edge Battery Replacement: 4 단계, 이미지 2/2
    • Slide the opening pick up along the side of the phone, separating the adhesive.
    • Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
    • Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
  5. Samsung Galaxy S7 Edge Battery Replacement: 5 단계, 이미지 1/3 Samsung Galaxy S7 Edge Battery Replacement: 5 단계, 이미지 2/3 Samsung Galaxy S7 Edge Battery Replacement: 5 단계, 이미지 3/3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
  6. Samsung Galaxy S7 Edge Battery Replacement: 6 단계, 이미지 1/2 Samsung Galaxy S7 Edge Battery Replacement: 6 단계, 이미지 2/2
    • Lift the glass and remove it from the phone.
  7. Samsung Galaxy S7 Edge Battery Replacement: 7 단계, 이미지 1/2 Samsung Galaxy S7 Edge Battery Replacement: 7 단계, 이미지 2/2
    • To install a new back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • If you're reinstalling the old back cover, or using a back cover without adhesive pre-installed, follow this guide.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
  8. Samsung Galaxy S7 Edge Battery Replacement, Loudspeaker Assembly: 8 단계, 이미지 1/1
    • Remove the twelve 3.5 mm Phillips screws.
  9. Samsung Galaxy S7 Edge Battery Replacement: 9 단계, 이미지 1/2 Samsung Galaxy S7 Edge Battery Replacement: 9 단계, 이미지 2/2
    • Use the small notch on the lower left of the upper antenna to pry it out of the phone.
    • Remove the upper antenna.
  10. Samsung Galaxy S7 Edge Battery Replacement: 10 단계, 이미지 1/1
    • Lift and remove the wireless charging coil from the phone.
  11. Samsung Galaxy S7 Edge Battery Replacement: 11 단계, 이미지 1/1
    • Lift and remove the loudspeaker from the phone.
  12. Samsung Galaxy S7 Edge Battery Replacement, Battery Disconnect: 12 단계, 이미지 1/2 Samsung Galaxy S7 Edge Battery Replacement, Battery Disconnect: 12 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the battery connector.
  13. Samsung Galaxy S7 Edge Battery Replacement, Battery: 13 단계, 이미지 1/1
    • Prepare an iOpener and apply it directly to the battery.
    • Alternatively, apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
  14. Samsung Galaxy S7 Edge Battery Replacement: 14 단계, 이미지 1/2 Samsung Galaxy S7 Edge Battery Replacement: 14 단계, 이미지 2/2
    • Use an opening pick to pry the battery from the bottom.
    • You will be prying against the case directly above the daughterboard and antenna cables. Pry carefully to avoid damaging either of these components.
    • You may need to reheat and reapply the iOpener repeatedly to further soften to adhesive. The adhesive is tough and it may take a few tries to get the pick started under the battery.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  15. Samsung Galaxy S7 Edge Battery Replacement: 15 단계, 이미지 1/2 Samsung Galaxy S7 Edge Battery Replacement: 15 단계, 이미지 2/2
    • Slide the opening pick up the side of the battery to break apart any remaining adhesive.
  16. Samsung Galaxy S7 Edge Battery Replacement: 16 단계, 이미지 1/2 Samsung Galaxy S7 Edge Battery Replacement: 16 단계, 이미지 2/2
    • Lift the battery out of the case.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery and adhesive, follow this guide.
결론
After completing this guide, calibrate your newly-installed battery.
다른 120명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 2018년 01월 03일
207,731 평판
안내서 437개 작성하였습니다
iFixit iFixit 회원
Community
146 회원들
안내서 16,116개 작성하였습니다
12 Comments
EXCELLENT TUTORIEL CLAIR ET PRECIS…….reussite du remplacement de la batterie ENCORE MERCI
daberalem - 답글
Super Anleitung und super Werkzeug! War in 45 Minuten mit allem fertig und bin begeistert!
Lars Gang - 답글
How.. in the bloody !&&*.. do you use the battery adhesive? Don’t just stop with the removal. Reapplication of the adhesive is an IMPORTANT STEP!
Doug Weber - 답글
Hi Doug,
I’ve written up a short guide for the battery adhesive. You can find it here. It’s now added into the last step. Hope that helps!
Arthur Shi -
1-2 hours…acturally about 30 mins! excellent tutorial
Sean Celestine - 답글
댓글 쓰기
조회 통계:
24 시간 전: 39
7일 전: 285
30일 전: 1,116
전체 시간: 110,441
