주요 콘텐츠로 건너뛰기
Samsung Galaxy S7 Edge Rear Camera Lens Replacement
필요한 것
    • Follow this procedure if you are replacing only the glass lens over the rear-facing camera.
    • If you are replacing the entire bezel, skip this step and follow the instructions in the next step.
    • Follow this longer procedure to replace the bezel and camera lens, which are installed on the rear case.
    • If you follow this procedure, you will need new adhesive to reinstall the rear case. Follow this guide to reinstall the camera bezel adhesive as well as the rear cover adhesive.
결승점
다른 18명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 02/05/15
223,409 평판
안내서 168개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 22
전체 시간: 22,168
