이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If your main camera glass is broken, you can either remove and replace the lens glass, or replace the whole lens assembly.
Removing the lens while the phone is still assembled may cause small pieces of glass to fall into the camera, but is a faster fix that requires less disassembly.
The lens assembly replacement is longer, and requires removing the back panel, but it is less likely to damage the camera itself. This procedure includes replacing the glass lens and the camera bezel, and will require replacement rear glass adhesive.
필요한 것
Follow this procedure if you are replacing only the glass lens over the rear-facing camera.
Follow this longer procedure to replace the bezel and camera lens, which are installed on the rear case.
다른 18명이 해당 안내서를 완성하였습니다.
