소개
Use this guide to replace or remove the battery in your Samsung Galaxy S8 Active.
This guide involves removing the back cover of the device, so you will need replacement adhesive to reattach the back cover to the phone.
Before disassembling your device, be sure the battery is charged below 25%. If accidentally punctured or damaged, the battery can catch fire and/or explode; if discharged below 25%, the chances of fire/explosion is decreased.
Follow the iOpener Heating guide for instructions on using the iOpener.
필요한 것
Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
Press gently to eject the SIM tray.
Remove the SIM card tray from the device.
Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
Take off the rubber bumpers from the top and bottom edges of the device.
Insert the Jimmy tool under the edge of the back cover.
Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
Slide the Jimmy tool down the sides of the device, separating the adhesive.
Place the heated iOpener across the top of the battery for approximately three minutes to soften the adhesive holding the battery to the device.
다른 30명이 해당 안내서를 완성하였습니다.
댓글 7개
Where can I order the batter
I need to do this repair. Can’t seem to find the battery on here.
Nice guide!
I still managed to rip the fingerprint cable tho ¯\_(ツ)_/¯
I completed this, the hardest parts were: 1. When prying up the battery, the back of the screen is directly under it! Any nicks or scratches will completely damage the screen! yikes. 2. when going back through and replacing the step 8 part, make sure the pieces are completely in line and the screws are not even a tiny bit crooked.
Thanks for the guide!
