주요 콘텐츠로 건너뛰기
Samsung Galaxy S8 Active Camera Glass Replacement
필요한 것
  1. Samsung Galaxy S8 Active Camera Glass Replacement, Camera Glass: 1 단계, 이미지 1/1
    • Lay phone face down and remove any coverings to the camera area. This way there are no obstructions to the repair area.
  2. Samsung Galaxy S8 Active Camera Glass Replacement: 2 단계, 이미지 1/1
    • Turn on the heat gun and hold it 3-4 inches from the glass for 5 seconds, waving it gently over the area to evenly distribute heat.
    • It may be helpful to keep the case on during this step, to avoid excessively heating the adhesive of the back panel.
  3. Samsung Galaxy S8 Active Camera Glass Replacement: 3 단계, 이미지 1/2 Samsung Galaxy S8 Active Camera Glass Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Gently remove the glass with tweezers.
    • If the adhesive is still strong, utilize the heat gun for another 3-5 seconds, waving it over the area.
  4. Samsung Galaxy S8 Active Camera Glass Replacement: 4 단계, 이미지 1/1
    • Check the surface for any residue or broken glass from previous cover.
  5. Samsung Galaxy S8 Active Camera Glass Replacement: 5 단계, 이미지 1/1
    • Center the new glass over the camera lens and lower it to the phone, careful to not scratch the exposed camera lens.
  6. Samsung Galaxy S8 Active Camera Glass Replacement: 6 단계, 이미지 1/1
    • Press gently on the perimeter of the glass to ensure a strong bond between the glass and the phone, but not pressing hard enough to break the glass.
결론
The device should be in working condition after the last step. Be sure to turn on the phone and verify to see if there are any obstructions to the camera view caused by the new glass covering.
다른 한 분이 해당 안내서를 완성하였습니다.
Anirudh Iyengar
회원 가입일: 02/01/20
142 평판
안내서 1개 작성함
댓글 한 개
Did you use the rear camera glass from Amazon that you've put a link to under parts? The Amazon seller has stated that it doesn't fit the Samsung S8 Active so unsure whether to purchase. Thanks
Natasha Wightman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 855
