주요 콘텐츠로 건너뛰기
Samsung Galaxy S8 Active Motherboard Replacement
필요한 것
  1. Samsung Galaxy S8 Active Motherboard Replacement, SIM Tray/Card: 1 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement, SIM Tray/Card: 1 단계, 이미지 2/2
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. Samsung Galaxy S8 Active Motherboard Replacement, NFC Antenna and Charging Coil Assembly: 2 단계, 이미지 1/3 Samsung Galaxy S8 Active Motherboard Replacement, NFC Antenna and Charging Coil Assembly: 2 단계, 이미지 2/3 Samsung Galaxy S8 Active Motherboard Replacement, NFC Antenna and Charging Coil Assembly: 2 단계, 이미지 3/3
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
  3. Samsung Galaxy S8 Active Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. Samsung Galaxy S8 Active Motherboard Replacement: 4 단계, 이미지 1/3 Samsung Galaxy S8 Active Motherboard Replacement: 4 단계, 이미지 2/3 Samsung Galaxy S8 Active Motherboard Replacement: 4 단계, 이미지 3/3
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
  5. Samsung Galaxy S8 Active Motherboard Replacement: 5 단계, 이미지 1/1
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  6. Samsung Galaxy S8 Active Motherboard Replacement: 6 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement: 6 단계, 이미지 2/2
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  7. Samsung Galaxy S8 Active Motherboard Replacement: 7 단계, 이미지 1/3 Samsung Galaxy S8 Active Motherboard Replacement: 7 단계, 이미지 2/3 Samsung Galaxy S8 Active Motherboard Replacement: 7 단계, 이미지 3/3
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
  8. Samsung Galaxy S8 Active Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
  9. Samsung Galaxy S8 Active Motherboard Replacement, Loudspeaker Assembly: 9 단계, 이미지 1/3 Samsung Galaxy S8 Active Motherboard Replacement, Loudspeaker Assembly: 9 단계, 이미지 2/3 Samsung Galaxy S8 Active Motherboard Replacement, Loudspeaker Assembly: 9 단계, 이미지 3/3
    • Remove the loudspeaker assembly using the flat end of a spudger.
  10. Samsung Galaxy S8 Active Motherboard Replacement, Iris Scanner: 10 단계, 이미지 1/3 Samsung Galaxy S8 Active Motherboard Replacement, Iris Scanner: 10 단계, 이미지 2/3 Samsung Galaxy S8 Active Motherboard Replacement, Iris Scanner: 10 단계, 이미지 3/3
    • Disconnect the iris scanner flex cable from the motherboard using the flat end of a spudger.
    • Use tweezers to gently lift the iris scanner from its slot.
  11. Samsung Galaxy S8 Active Motherboard Replacement, Front-Facing Camera: 11 단계, 이미지 1/3 Samsung Galaxy S8 Active Motherboard Replacement, Front-Facing Camera: 11 단계, 이미지 2/3 Samsung Galaxy S8 Active Motherboard Replacement, Front-Facing Camera: 11 단계, 이미지 3/3
    • Disconnect the front-facing camera flex cable from the motherboard using the flat end of a spudger.
    • Use tweezers to gently lift the camera from its slot.
  12. Samsung Galaxy S8 Active Motherboard Replacement, Motherboard: 12 단계, 이미지 1/3 Samsung Galaxy S8 Active Motherboard Replacement, Motherboard: 12 단계, 이미지 2/3 Samsung Galaxy S8 Active Motherboard Replacement, Motherboard: 12 단계, 이미지 3/3
    • Disconnect the battery flex cable using the flat end of a spudger.
  13. Samsung Galaxy S8 Active Motherboard Replacement: 13 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement: 13 단계, 이미지 2/2
    • Remove one 3.5 mm screw using a Phillips #00 Screwdriver.
  14. Samsung Galaxy S8 Active Motherboard Replacement: 14 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement: 14 단계, 이미지 2/2
    • Disconnect the Volume Up, Volume Down, and Bixby button flex cable using the flat end of a spudger.
  15. Samsung Galaxy S8 Active Motherboard Replacement: 15 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement: 15 단계, 이미지 2/2
    • Disconnect the display flex cable using the flat end of a spudger.
  16. Samsung Galaxy S8 Active Motherboard Replacement: 16 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement: 16 단계, 이미지 2/2
    • Disconnect the charging port flex cable using the flat end of a spudger.
  17. Samsung Galaxy S8 Active Motherboard Replacement: 17 단계, 이미지 1/3 Samsung Galaxy S8 Active Motherboard Replacement: 17 단계, 이미지 2/3 Samsung Galaxy S8 Active Motherboard Replacement: 17 단계, 이미지 3/3
    • Disconnect the black and white antenna cables using the flat end of a spudger.
  18. Samsung Galaxy S8 Active Motherboard Replacement: 18 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement: 18 단계, 이미지 2/2
    • The motherboard rests on top of the daughterboard, and there is a flex cable connecting them. Disconnect the flex cable that connects the motherboard to the daughterboard using the flat end of a spudger.
  19. Samsung Galaxy S8 Active Motherboard Replacement: 19 단계, 이미지 1/2 Samsung Galaxy S8 Active Motherboard Replacement: 19 단계, 이미지 2/2
    • Position the flat end of a spudger at the top edge of the motherboard.
    • Carefully pry up and remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erik Mauk
회원 가입일: 01/24/19
1,411 평판
안내서 6개 작성하였습니다
Cal Poly, Team S2-G1, White Winter 2019 Cal Poly, Team S2-G1, White Winter 2019 회원
CPSU-WHITE-W19S2G1
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 2,162
