소개
Use this guide to remove or replace the SIM card or SIM tray in your Samsung Galaxy S8.
필요한 것
Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
Press to eject the tray.
Remove the SIM card tray from the phone.
After you've completed the repair, follow this guide to test your repair.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 5개
Is this sim tray water proof with the rubber seal or no?
And what colors does it come in?
Is the Galaxy S8 similar to the Galaxy S8+ ?
Is installing the SIM card in the Galaxy S8 similar to installing the SIM card into the Galaxy S8+ ?
My tray actually broke off inside it, I could not remove it far enough to even get the sim card in it, only the sd card, is there a way to open it up?
Did you find a way?
