주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S8 SIM Card Tray Replacement
필요한 것
  1. Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: 1 단계, 이미지 3개 중 1개 Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: 1 단계, 이미지 3개 중 2개 Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: 1 단계, 이미지 3개 중 3개
    • Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
    • Press to eject the tray.
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
결론
After you've completed the repair, follow this guide to test your repair.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
218,575 평판
안내서 416개를 작성함
6가이드 댓글
Is this sim tray water proof with the rubber seal or no?
And what colors does it come in?
Darryl Bass - 답글
Is the Galaxy S8 similar to the Galaxy S8+ ?
travislwright2016 - 답글
Is installing the SIM card in the Galaxy S8 similar to installing the SIM card into the Galaxy S8+ ?
My tray actually broke off inside it, I could not remove it far enough to even get the sim card in it, only the sd card, is there a way to open it up?
Eric Hogarth - 답글
Did you find a way?
Jonathan Tsikire -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 62
지난 30일: 277
전체 시간: 43,138
