주요 콘텐츠로 건너뛰기
Samsung Galaxy S8 SIM Card Tray Replacement
필요한 것
  1. Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: 1 단계, 이미지 1/3 Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: 1 단계, 이미지 2/3 Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: 1 단계, 이미지 3/3
    • Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
    • Press to eject the tray.
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Vielen Dank!
    Ist die SIM+SDcard-Tray vom Samsung Galaxy S8 und Samsung Galaxy S8 Plus gleich?
    Bzw. kann ich eine SIM+SDcard-Tray von einem Samsung Galaxy S8 in einem Samsung Galaxy S8 Plus verwenden?
    Photelegy - 답글
    How do you fix it if the sim card tray is broken and did not fully eject?
    A Google User - 답글
결론
After you've completed the repair, follow this guide to test your repair.
다른 8명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
196,299 평판
안내서 416개 작성하였습니다
댓글 5개
Is this sim tray water proof with the rubber seal or no?
And what colors does it come in?
Darryl Bass - 답글
Is the Galaxy S8 similar to the Galaxy S8+ ?
travislwright2016 - 답글
Is installing the SIM card in the Galaxy S8 similar to installing the SIM card into the Galaxy S8+ ?
My tray actually broke off inside it, I could not remove it far enough to even get the sim card in it, only the sd card, is there a way to open it up?
Eric Hogarth - 답글
Did you find a way?
Jonathan Tsikire -
댓글 쓰기
조회 통계:
24 시간 전: 21
7일 전: 99
30일 전: 379
전체 시간: 36,300
