주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung Galaxy S8 수리는 자사의 서비스 설명서를 사용하세요.
  1. Samsung Galaxy S8 Teardown, Samsung Galaxy S8 Teardown: 1 단계, 이미지 3개 중 1개 Samsung Galaxy S8 Teardown, Samsung Galaxy S8 Teardown: 1 단계, 이미지 3개 중 2개 Samsung Galaxy S8 Teardown, Samsung Galaxy S8 Teardown: 1 단계, 이미지 3개 중 3개
    • Samsung seems to have gone all-out to provide the same smartphone experience regardless of your screen size preferences, and the Galaxy S8's specs bear that out. Any of this look familiar?
    • 5.8-inch, dual-edge, Super AMOLED display with 2960 × 1440 resolution (570 ppi)
    • Qualcomm Snapdragon 835 or Samsung Exynos 8895 processor, with 4 GB RAM
    • 12-megapixel rear camera with dual pixel autofocus and 4K video capture; 8-megapixel selfie camera
    • 64 GB internal storage, expandable via MicroSD card (up to 256 GB additional)
    • IP68 water resistance rating
    • Android 7.0 Nougat
  2. Samsung Galaxy S8 Teardown: 2 단계, 이미지 3개 중 1개 Samsung Galaxy S8 Teardown: 2 단계, 이미지 3개 중 2개 Samsung Galaxy S8 Teardown: 2 단계, 이미지 3개 중 3개
    • Dimensions aside, the S8 fairly identically clones the look of the S8+. Features include:
    • Speaker grille and microphone hole
    • USB-C charging port and headphone jack (Apple: 0 Samsung: 1)
    • Pulse reader/flash assembly
    • Rear-facing camera
    • Fingerprint reader
    • The S8 is a safe evolution on the S7 Edge—proportions, camera and sensor package location, and size are all fairly on par.
  3. Samsung Galaxy S8 Teardown: 3 단계, 이미지 3개 중 1개 Samsung Galaxy S8 Teardown: 3 단계, 이미지 3개 중 2개 Samsung Galaxy S8 Teardown: 3 단계, 이미지 3개 중 3개
    • The Galaxy once again rocks the glass-on-glass design, making our lives difficult. We heat the heck out of this panel and apply plenty of prying picks.
    • Once we get an edge open, the iSclack helps us crank through the rest of the gnarly adhesive (which will need replacing upon reassembly—*groan*).
    • And we're in—to an S8+? This guy looks pretty darn identical.
  4. Samsung Galaxy S8 Teardown: 4 단계, 이미지 2개 중 1개 Samsung Galaxy S8 Teardown: 4 단계, 이미지 2개 중 2개
    • The fingerprint sensor lives in the rear case, somewhat controversially placed. Using the thing (with your right hand) requires blindly stretching and blotting out the camera...
    • The good news is that this sensor is modular and can be popped right off its adhesive for replacement. All it takes is a little heat and a good push.
    • No word (yet) whether software locks (à la iPhone 7) will prevent a replacement from functioning.
  5. Samsung Galaxy S8 Teardown: 5 단계, 이미지 1개 중 1개
    • As with its S8+ sibling, the S8 employs some sweet hardware multitasking. The speaker/antenna array, and antenna/NFC coil assembly, do double duty as the phone's midframe.
    • Also like the S8+, the NFC antenna presumably does an additional job, spoofing MST to use Samsung Pay at any card reading checkout location.
    • We're almost running out of things to say here—the rest of the phone looks pretty much like the S8+ too, down to the wee pancake vibrator. It's like someone left the S8+ in their pocket on laundry day and it came out of the wash slightly shrunken, but no worse for wear.
  6. Samsung Galaxy S8 Teardown: 6 단계, 이미지 3개 중 1개 Samsung Galaxy S8 Teardown: 6 단계, 이미지 3개 중 2개 Samsung Galaxy S8 Teardown: 6 단계, 이미지 3개 중 3개
    • You'd think that after Samsung's less than stellar battery record, they'd have a quick eject system for these little bombs packs. And yet, this cell is firmly (and we mean firmly) adhered.
    • And it's not like it's especially hard to have a removable battery—it's done all over the phone world.
    • The Samsung-branded battery clocks in at 11.55 Wh—comparable to the Google Pixel's 10.66 Wh, but dwarfing the (slightly smaller) iPhone 7's 7.45 Wh battery.
    • The capacity comparison may look impressive, but reports seem to suggest that the actual performance is nothing to cheer about.
  7. Samsung Galaxy S8 Teardown: 7 단계, 이미지 3개 중 1개 Samsung Galaxy S8 Teardown: 7 단계, 이미지 3개 중 2개 Samsung Galaxy S8 Teardown: 7 단계, 이미지 3개 중 3개
    • The I/O board connector is under the motherboard in these late-model Galaxy phones. Because why not make things harder?
    • The motherboard itself pops out with relative ease, giving us a peep at that now-Samsung-standard heatpipe.
    • The I/O daughterboard configuration matches the S8+ right down to the modular headphone jack.
    • Since we've already gone through the camera shenanigans, let's get straight to the chips.
  8. Samsung Galaxy S8 Teardown: 8 단계, 이미지 1개 중 1개
    • We checked the genetics chips in the S8 to see if it is truly a smaller twin of the S8+:
    • Samsung K3UH5H50MM-NGCJ 4 GB LPDDR4 RAM layered over the MSM8998 Snapdragon 835
    • Toshiba THGBF7G9L4LBATR 64 GB UFS (NAND flash + controller)
    • Qualcomm WCD9341 Aqstic audio codec
    • Skyworks SKY78160-11 WLAN front end module
    • Avago AFEM-9066 power amplifier module
    • NXP Semiconductor PN80T NFC controller w/ secure element
    • Silicon Mitus SM5720 interface PMIC
  9. Samsung Galaxy S8 Teardown: 9 단계, 이미지 1개 중 1개
    • On the opposite side we find:
    • Murata KM6D28040 Wi-Fi Module
    • Qualcomm PM8998 (similar to PM8920) Power Management
    • Qualcomm WTR5975 RF Transceiver
    • Avago AFEM-9053 power amplifier (likely)
    • IDT P9320S wireless power receiver
    • Maxim MAX77838 companion PMIC (similar to MAX77829) (for AMOLED displays)
    • Samsung S59X7P1 image processor (likely)
  10. Samsung Galaxy S8 Teardown: 10 단계, 이미지 2개 중 1개 Samsung Galaxy S8 Teardown: 10 단계, 이미지 2개 중 2개
    • IC Identification, pt. 2:
    • RDA Microelectronics RDA6213N FM transceiver (likely)
    • Skyworks SKY13716-11 low band LNA front end module
    • Qualcomm ? D5319 mid-band diversity
    • Qualcomm ? D5320 high-band diversity (likely)
    • Skyworks SKY77365-11 power amplifier module
    • NXP Semiconductor BGU8103 GPS/GLONASS/Galileo/BeiDou Low Noise Amplifier
    • NXP Semiconductor PCAL6524 24-bit I/O expander
  11. Samsung Galaxy S8 Teardown: 11 단계, 이미지 2개 중 1개 Samsung Galaxy S8 Teardown: 11 단계, 이미지 2개 중 2개
    • IC Identification, pt. 3:
    • Maxim MAX98506 audio amplifier
    • Qualcomm PM8008 power management
    • Samsung S2MPB02 power management
    • Samsung S2MM005X02 USB power delivery controller (likely)
    • ON Semiconductor FPF3688UCX load switch
    • ON Semiconductor FAN48618 voltage regulator and Richtek RT8010GQW 1 A DC/DC converter
    • Vishay DG2730 2 port, 480 Mbps DPDT USB 2.0 analog switch and NXP Semiconductor NCX2200 comparator
  12. Samsung Galaxy S8 Teardown: 12 단계, 이미지 2개 중 1개 Samsung Galaxy S8 Teardown: 12 단계, 이미지 2개 중 2개
    • IC Identification, pt. 4 (sensors):
    • STMicroelectronics LSM6DSL 3-axis accelerometer/gyroscope
    • STMicroelectronics LPS22HB Pressure Sensor
    • AKM Semiconductor AK09916C 3-axis electronic compass
    • Ablic (formerly Seiko Instruments) S-5712CCDL1-I4T1U Hall Effect Sensor
    • Semtech SX9320 Proximity Sensor (likely)
    • Analog Devices ? Heart Rate Sensor
  13. Samsung Galaxy S8 Teardown: 13 단계, 이미지 1개 중 1개
    • That's it for the vanilla S8. If you haven't already guessed, we've got a more detailed breakdown of the S8+, so check it out if you haven't already.
    • With that, let's give the Galaxy S8 its repairability score.
  14. 최종 의견
    • Lots of components are modular and can be replaced independently.
    • The battery can be replaced, but tough adhesive and a glued-on rear panel make it unnecessarily difficult.
    • Front and back glass make for double the crackability, and strong adhesive on both makes it tough to access the internals for any repair.
    • Because of the curved screen, replacing the front glass without destroying the display is extremely difficult.
    수리 용이성 점수
    4
    수리 용이성 10점 중 4점
    (10은 가장 쉬운 수리를 뚯함)
41가이드 댓글
With the release of the Samsung Galaxy S8 and S8+, Samsung has begun building new "Wizard Lounges" at which Samsung officials can personally tell you "your phone is broken, buy a new one!"
George A. - 답글
+1 for the best review I have seen on this so far.
Kendall Paisley -
Very nice Photography!
Tecnopolis Magazine - 답글
I would like to know how heavy the battery is compared with the S7 battery and how big (volume) it is
Henning Holthusen - 답글
From memory, (did a teardown just recently,) the S8 Battery is significantly heavier than an S7 battery. It is quite a bit thinner however, so the added weight must be caused by the internals. I'm no expert on battery composition but I know for sure that S8 batteries are much more durable from a repairers point-of-view.
Harry Rowse -
댓글 쓰기
조회 통계:
지난 24시간: 39
지난 7일: 206
지난 30일: 853
전체 시간: 313,575
