소개
在某数学不好的手机厂商和操作系统厂商直接从8跳到X后,三星仍不为所动地带来了Galaxy S9+(甚至没有刘海)。只有拆解能告诉我们这部手机是一个强劲的对手,还是一个奇葩的AR表情机器。
我们同样有Samsung Galaxy S9的拆解视频,来看一看吧!
对于iFixit来说,除了拆解之外我们还有更多的内容!请关注我们的Facebook, Twitter, and Instagram去了解这部手机的全部的最新状态吧!
필요한 것
以下向你展示S9+的各项配置
无刘海的2960 x 1440分辨率6.2英寸AMOLED屏幕(~530ppi)
高通骁龙845处理器(或三星猎户座9810,取决于地区)
1200万像素光学防抖主摄像头——ƒ/1.5或ƒ/2.4可变光圈——加一个1200万像素光学防抖长焦摄像头和一个800万像素前置摄像头。
耳机孔和microSD卡槽
IP68级别防水防尘
Android 8.0 奥利奥
尽管有2个传感器,这个双摄像头是用一块电路板和一个端口的一整个模组!
算上后置的双摄,S9+一共包含了4颗摄像头,另外两颗为前置摄像头以及虹膜摄像头
与去年的“梦幻”相机相对于,今年的相机被称为“Star”
我们在TechInsights的伙伴拆开了这个摄像头,并发现其中藏有芯片。三星声称他们在相机中集成的内存能让相机多获得四倍的图像数据。960FPS慢动作?
主板正面的元件:
三星(Samsung)K3UH6H6-NGCJ 6 GB LPDDR4X内存,高通骁龙845处理器在其下层。
东芝(Toshiba)THGAF4G9N4LBAIR 64 GB UFS存储(NAND闪存&控制器)
安华高(AVAGO)AFEM-9096 KM1746
高通(Qualcomm)Aqstic™ WCD9341音频编解码器
美信公司 (Maxim) MAX77705F 电源管理集成电路
高通(Qualcomm)QET4100 包络追踪无线电放大器
美信公司(Maxim) MAX98512 音频功放
反面:
村田(Murata)KM7N16048 无线局域网&蓝牙模块
恩智浦(NXP)PN80T NFC控制器
高通(Qualcomm)PM845 电源管理集成电路
高通(Qualcomm)SDR845 101 无线电收发器
Skyworks SKY78160-11 前端模组
高通(Qualcomm)PM8005 电源管理集成电路
다음 번역가들에게 특별히 감사 드립니다:
65%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 41개
Just like the S8 being called the “Dream”, the Note 8 was called the “Great” and the S9 is called the “Star.“ So yes, there are fingerprint sensors out there called the “Dream Finger,“ “Great Finger,“ and “Star Finger.“ Weird, yet hilarious.
Hey look at that “DREAM FINGER” right here on the S8 cable! Great info!
Lmao, I hope you understand your referring to the ribbon and not the entire sensor; I am not at liberty to correct you, but lookup the description of a fingerprint sensor from a genuine OEM authorized reseller
Yes, I do understand that I am referring to the ribbon, that’s why I called it a cable. It’s not a leap to assume that the cable is carrying the label for the assembly. Just like the “S9+” printed on the rear case represents the whole phone, not just the glass.
The sticky black webbing on the battery is most likely a thermal pad to assist with heat dissipation. An air gap, even a tiny one (microns) still acts as a poor thermal conductor.
