소개
Use this guide to replace a cracked or broken display on your Samsung Galaxy S9.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the display while leaving the original frame, motherboard, and battery in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure—transplanting your phone's internals and installing a new battery. Make sure you have the correct part before starting this guide.
This guide involves removing the rear glass cover; you will need replacement adhesive to reattach the back cover to the phone. If your replacement display does not come with adhesive, use a strong double-sided tape such as Tesa 61395 to secure it.
Opening the Samsung Galaxy S9 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally, but will lose its water protection.
If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
필요한 것
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
Use the flat end of a spudger to pry up and disconnect the battery flex cable.
Remove the two 4 mm Phillips #00 screws holding the plastic cover in place.
Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
Lay overlapping strips of clear packing tape over the display until the whole face is covered.
This will keep glass shards contained and provide structural integrity when prying and lifting the display.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
After you've completed the repair, follow this guide to test your repair.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
다른 75명이 해당 안내서를 완성하였습니다.
댓글 5개
A bit of guidance on where the adhesive seal goes would be nice. I believe I got it right.
john bromm - 답글
digitizer is stuck to glass, and came apart
I followed the entire guide and still got a black screen of death.
Na het uitvoeren van alle stappen kwam ik een goudfolie tegen achter het scherm. Deze zie ik niet terug in jouw beschrijving. Wat kan ik doen?
