주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S9 Plus Rear Glass Removal
필요한 것
  1. Samsung Galaxy S9 Plus Rear Glass Removal, Rear Glass Removal: 1 단계, 이미지 1개 중 1개
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Samsung Galaxy S9 Plus is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  2. Samsung Galaxy S9 Plus Rear Glass Removal: 2 단계, 이미지 1개 중 1개
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
    댓글 쓰기
  3. Samsung Galaxy S9 Plus Rear Glass Removal: 3 단계, 이미지 2개 중 1개 Samsung Galaxy S9 Plus Rear Glass Removal: 3 단계, 이미지 2개 중 2개
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap and slide it to the bottom right corner.
    댓글 쓰기
  4. Samsung Galaxy S9 Plus Rear Glass Removal: 4 단계, 이미지 2개 중 1개 Samsung Galaxy S9 Plus Rear Glass Removal: 4 단계, 이미지 2개 중 2개
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick at the bottom end of the phone. This opening pick stays there during the rear glass removal procedure to prevent the adhesive from resealing.
    댓글 쓰기
  5. Samsung Galaxy S9 Plus Rear Glass Removal: 5 단계, 이미지 2개 중 1개 Samsung Galaxy S9 Plus Rear Glass Removal: 5 단계, 이미지 2개 중 2개
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the S9 Plus.
    • Leave the opening pick in its place after you cut the adhesive half way up the left side of the phone.
    • Slide the opening pick from the bottom right corner half way up the frame and leave it there.
    댓글 쓰기
  6. Samsung Galaxy S9 Plus Rear Glass Removal: 6 단계, 이미지 2개 중 1개 Samsung Galaxy S9 Plus Rear Glass Removal: 6 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick at the right side of the frame and slide it to the top right corner.
    • Slide a fifth opening pick along the left side of the phone to the top left corner.
    • Use the opening pick to cut the remaining adhesive under the upper part of the rear glass.
    • Don't open the phone all the way yet. The flex cable for the fingerprint reader is still connected to the motherboard.
    댓글 쓰기
  7. Samsung Galaxy S9 Plus Rear Glass Removal: 7 단계, 이미지 2개 중 1개 Samsung Galaxy S9 Plus Rear Glass Removal: 7 단계, 이미지 2개 중 2개
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
    댓글 쓰기
  8. Samsung Galaxy S9 Plus Rear Glass Removal: 8 단계, 이미지 1개 중 1개
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
    댓글 쓰기
결론
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
After you've completed the repair, follow this guide to test your repair.
취소: 해당 안내서를 완성하지 않았습니다.
다른 21명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
260,657 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 27,525개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 38
지난 30일: 150
전체 시간: 42,571
