소개
Replace the USB-C Charging Port (Daughterboard) in your Samsung Galaxy S9+.
필요한 것
동영상 지침
결론
다른 9명이 해당 안내서를 완성하였습니다.
3가이드 댓글
Hi..good morning.. I have this problem..they replaced my charging board with a new one because its not charging, and its charging again…the problem is…after they do the replacement..now the signal/network connection is gone. I’ve already did a factory reset hoping that its a software problem..but its still the same….the technician here said he dont know how tp fix this..hopefully you guys can help me with this
ys_hotel - 답글 공유
Sounds like something did not get plugged back in correctly after they replaced the daughter. Make sure and double check all connections I. The same order the video shows.
Mikeo52 - 답글 공유
I have the same issue, any idea how to fix the No signal symbol after changing the usb c port? Or the hardware is broken?
J.Franceschini - 답글 공유
