주요 콘텐츠로 건너뛰기
Samsung Galaxy S9 Plus USB-C Charging Port Replacement
필요한 것
동영상 지침
결론
다른 5명이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
112,881 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 2개
Hi..good morning.. I have this problem..they replaced my charging board with a new one because its not charging, and its charging again…the problem is…after they do the replacement..now the signal/network connection is gone. I’ve already did a factory reset hoping that its a software problem..but its still the same….the technician here said he dont know how tp fix this..hopefully you guys can help me with this
ys_hotel - 답글
Sounds like something did not get plugged back in correctly after they replaced the daughter. Make sure and double check all connections I. The same order the video shows.
Mikeo52 -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 21
30일 전: 89
전체 시간: 6,448
