소개
Use this guide to remove the rear glass of the Samsung Galaxy S9.
Opening the Samsung Galaxy S9 will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
필요한 것
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
After you've completed the repair, follow this guide to test your repair.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 한 개
Sollte nach Abschluss der Reparatur der Fingerabdrucksensor nicht funktionieren bitte folgende Schritte machen:
1. Schalte das Handy aus und hänge es ein Ladegerät
2. Starte das Handy im Restore Modus indem du die Bixby, Lauter und Powertaste gleichzeitig drückst bis das Samsung Logo kommt.
3. Wähle in dem Menü den Punkt: Wipe Cache Partition aus und bestätige mit Power deine Auswahl.
4. Starte das Gerät neu.
