주요 콘텐츠로 건너뛰기
Samsung Galaxy SIII Mini Camera Failed Troubleshooting
필요한 것
동영상 개요
  1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: 1 단계, 이미지 1/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: 1 단계, 이미지 2/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: 1 단계, 이미지 3/3
    • Go to:
    • > Settings
    • > Application manager
    • > All
    • >Camera
    • Clear data and cache and check that the camera works. If no, go to the next step.
  2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: 2 단계, 이미지 1/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: 2 단계, 이미지 2/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: 2 단계, 이미지 3/3
    • Go to:
    • > Settings > Backup and reset
    • > Factory data reset
    • > Reset device > Erase everithing
    • !!! This will erase all your data !!!
    • For a Hard reset using hardware keys, follow this manual:
    • Samsung Galaxy - Wipe data/Factory reset
  3. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: 3 단계, 이미지 1/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: 3 단계, 이미지 2/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: 3 단계, 이미지 3/3
    • Open sammobile and make an registration.
    • Search the firmware for your model and find the variant, corresponding to your mobile phone.
    • You can see the variant from Settings > About the device, or from dialer app by entering *#1234#
    • In the download page you can find instructions and link to the Odin app.
  4. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: 4 단계, 이미지 1/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: 4 단계, 이미지 2/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: 4 단계, 이미지 3/3
    • Switch off the phone and remove the battery and any SIM and memory card.
    • Remove the Midframe.
    • Disconnect the Menu buttons and the SD card reader flex cables.
    • Lift the board slightly to the left side and be careful with the earpiece and the main camera - they are stuck to the Display frame.
  5. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: 5 단계, 이미지 1/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting: 5 단계, 이미지 2/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting: 5 단계, 이미지 3/3
    • Disconnect the LCD Display flex cable.
    • Open the camera flex cable connector and reconnect the camera.
  6. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: 6 단계, 이미지 1/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: 6 단계, 이미지 2/3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: 6 단계, 이미지 3/3
    • If the camera still does not work, the last step is camera replacement.
  7. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: 7 단계, 이미지 1/1
    • Did you do it successfully?
결론
다른 16명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 3개
I did it! I did it! I did it!
I save time and money!
Thank you sooooo much!
Batis Kaf - 답글
how did you do it?!
zohny.omar -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 9,552
