주요 콘텐츠로 건너뛰기
Samsung Galaxy SIII Mini VE Battery Replacement
필요한 것
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: 1 단계, 이미지 1/3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: 1 단계, 이미지 2/3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: 1 단계, 이미지 3/3
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: 2 단계, 이미지 1/2 Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: 2 단계, 이미지 2/2
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: 3 단계, 이미지 1/2 Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: 3 단계, 이미지 2/2
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Megan
회원 가입일: 10/23/14
1,186 평판
안내서 6개 작성하였습니다
Michigan Tech, Team 1-8, Lauer Fall 2014 Michigan Tech, Team 1-8, Lauer Fall 2014 회원
MTU-LAUER-F14S1G8
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 3,358
