주요 콘텐츠로 건너뛰기
Samsung Galaxy SIII Mini VE Front Camera Replacement
필요한 것
  1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: 1 단계, 이미지 3개 중 1개 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: 1 단계, 이미지 3개 중 2개 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: 1 단계, 이미지 3개 중 3개
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
  2. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: 2 단계, 이미지 2개 중 1개 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: 2 단계, 이미지 2개 중 2개
    • Use your finger or an opening tool to pry the battery out of the phone.
  3. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Screws: 3 단계, 이미지 1개 중 1개
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
  4. Samsung Galaxy SIII Mini VE Front Camera Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy SIII Mini VE Front Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Using an opening tool, gently separate the plastic framing from the phone.
  5. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: 5 단계, 이미지 3개 중 1개 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: 5 단계, 이미지 3개 중 2개 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
  6. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: 6 단계, 이미지 3개 중 1개 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: 6 단계, 이미지 3개 중 2개 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Locate the front camera connection.
    • Using the tweezers, lift the holding tab at the base of the ribbon wire.
    • Again, using the tweezers, gently pull the front camera out and away from the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Megan
회원 가입일: 10/23/14
1,228 평판
안내서 6개를 작성함
Michigan Tech, Team 1-8, Lauer Fall 2014 Michigan Tech, Team 1-8, Lauer Fall 2014 회원
MTU-LAUER-F14S1G8
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 1,256
