주요 콘텐츠로 건너뛰기
Samsung Galaxy Sol Front Camera Replacement
필요한 것
  1. Samsung Galaxy Sol Front Camera  Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Front Camera  Replacement: 2 단계, 이미지 1/1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Front Camera  Replacement, Front Camera: 3 단계, 이미지 1/1
    • Remove all ten 0.4 mm screws with a Phillips #00 screw bit. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Front Camera  Replacement: 4 단계, 이미지 1/1
    • Remove the front camera at the top left of the phone be carefully removing it with tweezers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tanner Monen
회원 가입일: 04/05/18
285 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 440
