주요 콘텐츠로 건너뛰기
Samsung Galaxy Sol Headphone Jack Replacement
필요한 것
  1. Samsung Galaxy Sol Headphone Jack Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 1/1
    • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
  4. Samsung Galaxy Sol Headphone Jack Replacement: 4 단계, 이미지 1/1
    • Turn the phone around and remove the screen using the plastic tool.
  5. Samsung Galaxy Sol Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Remove the headphone jack at the top of of the phone by carefully removing it with tweezers.
결론
Tanner Monen
회원 가입일: 04/05/18
285 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 335
