주요 콘텐츠로 건너뛰기
Samsung Galaxy Sol Speaker Replacement
필요한 것
  1. Samsung Galaxy Sol Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove all ten 0.4mm screws by unscrewing them with the Phillips #00 screwdriver. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Speaker Replacement: 4 단계, 이미지 1/1
    • This is the speaker that you will be removing in the next step.
  5. Samsung Galaxy Sol Speaker Replacement: 5 단계, 이미지 1/1
    • Using the curved tweezers, grab ahold of the gold piece of the speakers and slowly lift out of the speaker slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessica Naslund
회원 가입일: 04/05/18
139 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 387
