소개
For the Cricket Samsung Galaxy Sol, this guide will teach you how to replace the speaker. Some problems that may have caused issues with your speaker could be water damage, an old device, or a dirty speaker. This guide will show you how to easily replace your device's speaker.
필요한 것
Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
Remove all ten 0.4mm screws by unscrewing them with the Phillips #00 screwdriver. After this, you will be able to lift up and remove the grey plastic piece.
다른 한 분이 해당 안내서를 완성하였습니다.
