주요 콘텐츠로 건너뛰기
Samsung Galaxy Star Pro Speaker Replacement
필요한 것
  1. Samsung Galaxy Star Pro Speaker Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
  2. Samsung Galaxy Star Pro Speaker Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Star Pro Speaker Replacement: 2 단계, 이미지 2/2
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
  3. Samsung Galaxy Star Pro Speaker Replacement, Screen: 3 단계, 이미지 1/1
    • After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
  4. Samsung Galaxy Star Pro Speaker Replacement: 4 단계, 이미지 1/1
    • Once screws are removed turn the phone over and use the plastic opening tool and unclip the connector holding the screen to the motherboard.
    • Be careful to not damage the press-fit connector that connects the screen to the motherboard.
  5. Samsung Galaxy Star Pro Speaker Replacement: 5 단계, 이미지 1/1
    • Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
  6. Samsung Galaxy Star Pro Speaker Replacement, Motherboard: 6 단계, 이미지 1/2 Samsung Galaxy Star Pro Speaker Replacement, Motherboard: 6 단계, 이미지 2/2
    • Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
  7. Samsung Galaxy Star Pro Speaker Replacement, Speaker: 7 단계, 이미지 1/2 Samsung Galaxy Star Pro Speaker Replacement, Speaker: 7 단계, 이미지 2/2
    • Use plastic tools to grab hold of one side of the speaker on the motherboard, and then gently lift. There is nothing holding the speakers, so it should come right off.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Kevin Teque
회원 가입일: 03/10/16
318 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 7-2, Catania Spring 2016 UMass Dartmouth, Team 7-2, Catania Spring 2016 회원
UMASSD-CATANIA-S16S7G2
3 회원들
안내서 5개 작성하였습니다
댓글 2개
how cost spaeaker component
me good - 답글
thanks Alot…….
mido shora - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 1,250
