주요 콘텐츠로 건너뛰기
Samsung Galaxy Stardust Battery Replacement
필요한 것
  1. Samsung Galaxy Stardust Battery Replacement, Battery: 1 단계, 이미지 1/2 Samsung Galaxy Stardust Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Hold down the power button located on the right side of the phone.
    • After five seconds, the screen will display three different options. Select the "power off" option.
  2. Samsung Galaxy Stardust Battery Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Stardust Battery Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Stardust Battery Replacement: 2 단계, 이미지 3/3
    • Place your finger or opening tool in the hole on the side of the phone.
    • Carefully pull the back casing away from the phone while keeping the phone stable.
  3. Samsung Galaxy Stardust Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Stardust Battery Replacement: 3 단계, 이미지 2/2
    • Place both the phone and the phone casing next to each other with the battery facing upwards.
    • Carefully lift the battery from the indent above the battery, then place the battery next to the phone.
  4. Samsung Galaxy Stardust Battery Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Stardust Battery Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Stardust Battery Replacement: 4 단계, 이미지 3/3
    • Take your new battery and look for the plus and minus signs on the bottom of the battery.
    • Line up the signs to the three strips on the bottom of the phone.
    • Carefully place the battery in until it is secure inside the phone.
  5. Samsung Galaxy Stardust Battery Replacement: 5 단계, 이미지 1/1
    • Take the back of the phone and line up the circular hole to the camera.
    • Apply force to the back of the phone with your hand, until the back case snaps onto the phone and is secure.
결승점
Alan Kwong
회원 가입일: 03/22/21
121 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G11, Sinclaire Spring 2021 UMass Dartmouth, Team S1-G11, Sinclaire Spring 2021 회원
UMASSD-SINCLAIRE-S21S1G11
1 회원
안내서 2개 작성하였습니다
댓글 2개
bom dia como concertar o samsung A32
camargowil - 답글
bom dia podem me mandar ,para mim e outros armenque o esquema eletrico do samsung A32=SM-A32 5M/DS
como desmontar e se possivel o esquema eletrico.
camargowil - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 63
전체 시간: 2,619
