주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 10.1 S-Pen Speaker Replacement
필요한 것
  1. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: 1 단계, 이미지 1/2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 3 단계, 이미지 3/3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
  5. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 5 단계, 이미지 2/2
    • Remove the ribbon cable from the socket.
  6. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the two 4mm Phillips #000 screws from the speakers.
  7. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to pry the speakers out of the tablet
결론
다른 2명이 해당 안내서를 완성하였습니다.
Guneet Bawa
회원 가입일: 04/12/18
688 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S1-G5, Liner Spring 2018 UW Tacoma, Team S1-G5, Liner Spring 2018 회원
UWT-LINER-S18S1G5
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 370
