주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement, Back Panel: 1 단계, 이미지 1/1
    • Power off your tablet before you begin disassembly.
    • Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
  2. Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
    • Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
    • Continue to wedge the tool about every inch along the current edge.
  3. Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 3 단계, 이미지 2/2
    • Once the bottom edge has been loosened, work towards a bottom corner from the other edge and continue to wedge gently until you can “pop” the corner out.
    • Continue this process on the other bottom corner until it can be popped out as well.
  4. Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 4 단계, 이미지 1/1
    • Place your hand between the device and the back panel. Then continue the wedging motion along the top edge of the device until the back panel comes loose.
    • Do not wedge the tool directly on top of the power buttons and headphone jack. Wedge nearby so that you don’t damage internal hardware.
  5. Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 5 단계, 이미지 1/1
    • Remove the back from the device.
    • Excessive force shouldn't be necessary here. If the back panel is sticking, find the area of the edge closest to the sticking point and wedge the opening tool there until the back panel pops free.
  6. Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 6 단계, 이미지 2/2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • The connection between the battery and motherboard is a group of four wires in black housing that can be found near the top middle of the device. Using a plastic spudger or a flat, slim tool, lift the black connector housing upwards to disconnect it.
  7. Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement, Front Facing Camera: 7 단계, 이미지 1/2 Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement, Front Facing Camera: 7 단계, 이미지 2/2
    • The connection you need to unfasten is the orange rectangle with the black cable coming out of it. Slide either your nail or the metal spudger under that orange connection.
    • Gently pop the connection off the motherboard.
  8. Samsung Galaxy Tab 10.1 4G Front Facing Camera Replacement: 8 단계, 이미지 1/1
    • Remove the front facing camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ashley Stark
회원 가입일: 09/23/15
1,220 평판
안내서 6개 작성하였습니다
Baylor, Team 10-11, Williams Fall 2015 Baylor, Team 10-11, Williams Fall 2015 회원
BU-WILLIAMS-F15S10G11
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 315
