소개
There are a few things to do in order to replace the headphone jack. As always with a tablet, you must first remove the back panel and disconnect the battery to ensure your safety. Then you will use a small electronics screwdriver, preferably a Phillips #00, to remove 4 screws connecting the SIM card reader which bars access to the headphone port. Once that is done, a simple cable disconnection will free the headphone port. There is an adhesive that secures the port to the device. It's very stubborn but will eventually give.
필요한 것
Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
Continue to wedge the tool about every inch along the current edge.
Use a Phillips #00 screwdriver to remove all 4 black 2.5mm screws securing the silver SIM card reader to the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
