소개
In this guide, you will learn how to replace the LED flash light on your Samsung Galaxy Tab 10.1. Having a malfunctioning flash can lead to poor lighting in the pictures taken on the tablet. There are a couple prerequisites we need to get out of the way first!
필요한 것
Place the bottom of the tablet towards you.
Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
Carefully pull the three ribbon cables from their sockets on the motherboard.
Use your spudger to gently pry up the black connection of the LED flash from the motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
