주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement, Rear Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement, Rear Panel: 1 단계, 이미지 2/2
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 2 단계, 이미지 3/3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 3 단계, 이미지 3/3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  4. Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement, Battery: 4 단계, 이미지 1/3 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement, Battery: 4 단계, 이미지 2/3 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement, Battery: 4 단계, 이미지 3/3
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
  5. Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 5 단계, 이미지 2/2
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  6. Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 6 단계, 이미지 3/3
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
  7. Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement, Rear Facing Camera: 7 단계, 이미지 1/2 Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement, Rear Facing Camera: 7 단계, 이미지 2/2
    • Use the spudger to pry up on the white connection of the rear camera wire.
  8. Samsung Galaxy Tab 10.1 Rear Facing Camera Replacement: 8 단계, 이미지 1/1
    • Grab the white connection with your fingers and lift it up from its slot.
    • We have removed the motherboard in these pictures to make it easier to see, but it is not necessary to complete this step.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jess McCafferty
회원 가입일: 09/30/13
1,704 평판
안내서 2개 작성하였습니다
Cal Poly, Team 13-5, Forte Fall 2013 Cal Poly, Team 13-5, Forte Fall 2013 회원
CPSU-FORTE-F13S13G5
5 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 23
전체 시간: 2,484
