주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Tab 2 10.1 Front Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 2 단계, 이미지 2개 중 1개 Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Battery Disconnect: 3 단계, 이미지 1개 중 1개
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Front Camera: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Front Camera: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
  6. Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift the gold cable connector with the flat end of the heavy-duty spudger to disconnect it from the device.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Amy Tsai
회원 가입일: 01/30/15
2,005 평판
안내서 2개를 작성함
Cal Poly, Team 6-26, Amido Winter 2015 Cal Poly, Team 6-26, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G26
5 회원들
안내서 14개를 작성함
1가이드 댓글
Batri chahiye
hiadarkhandevelove - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 55
전체 시간: 2,110
