주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement
필요한 것
  1. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement, Auxiliary Port: 1 단계, 이미지 1/1
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert.
  2. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 2 단계, 이미지 1/1
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding holding the battery on the device.
  3. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 3 단계, 이미지 3/3
    • Gently detach the set of wires clips connecting the battery to the device using a nylon spudger.
    • Remove the battery and set it aside.
  4. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 4 단계, 이미지 1/1
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  5. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 5 단계, 이미지 3/3
    • Locate the flex cables attached to the motherboard. Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp tools have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  6. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 6 단계, 이미지 3/3
    • Locate the yellow brackets at the bottom of the device.
    • Using a phillips head screwdriver, remove the single 4mm screw on each bracket, located on either side of the auxiliary port.
    • Lift the brackets from the device and set them aside.
    • You may need to use a nylon spudger, or any flat tool, to lift the brackets out of their place.
  7. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 7 단계, 이미지 1/1
    • Using a nylon spudger, or any flat tool, gently pry and lift the small metal covering off of the auxiliary port.
    • This will reveal a rubber covering.
  8. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 8 단계, 이미지 1/1
    • Using a nylon spudger, or any flat tool, gently pry and lift the small rubber covering to expose the auxiliary port.
    • This will reveal the auxiliary port.
  9. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 9 단계, 이미지 1/1
    • Lift the auxiliary port with a nylon spudger.
    • Remove the auxiliary component.
    • It is easiest to lift this piece from the innermost side of the port, opposite of the opening.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Katija Tarailo
회원 가입일: 03/02/17
460 평판
안내서 3개 작성하였습니다
IUPUI, Team S3-G1, Harley Spring 2017 IUPUI, Team S3-G1, Harley Spring 2017 회원
IUPUI-HARLEY-S17S3G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 1,990
