주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal
동영상 개요
  1. Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal, Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal: 1 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal, Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal: 1 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal, Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal: 1 단계, 이미지 3/3
    • If you forgot your password, pattern drill, first you can try to sign in on your device by entering your Google account.
    • You must be in range of a network that already used.
    • The last step is factory reset.
    • This will erase all your private information.
  2. Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal: 2 단계, 이미지 2/2
    • Switch off the tablet.
    • Press and hold the Home, Volume Up and Power On buttons.
    • When you see the Galaxy logo, release the power On button
  3. Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 - Factory Reset Password Removal: 3 단계, 이미지 3/3
    • Now you are in the Android System Recovery menu.
    • Use Volume Up/Down keys for navigation and Power On for selection.
    • Select one by one:
    • wipe data/factory reset
    • Yes -- erase all user data
    • reset system now
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
결론
다른 24명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 6개
danke für die Hilfe, hat leider nicht funktioniert.
Jürg Brogli
Brogli - 답글
Muchas Gracias! thank you very much. super useful!
Alex - 답글
Thanks so much. I was trying to do factory reset. Other sites left out pressing the home button
michael kelly - 답글
I have a Samsung Galaxy tab 3 10 inch, when I turn it on I can't get past the samsung start up screen. I've tried the hard reset home power and vol up buttons but all I get is the samsung logo, any Ideas it was working earlier?
glynsmith06 - 답글
nothing worked
A bas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 51
전체 시간: 47,368
