주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 10.1 Battery Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Open Device: 1 단계, 이미지 1/1
    • Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
    • Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
    • During reassembly, be careful not to insert bottom, left, nor right edges first—doing so can damage the power button, and prevent the front panel from sitting totally flush.
    • If screen is cracked like shown imagine, Place tape on screen to prevent injury.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement, Ribbon Cables: 2 단계, 이미지 1/1
    • Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery Screws: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
    • Make sure to keep screws in a secure location for reassembly.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement, Removal: 4 단계, 이미지 1/1
    • Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
결론
다른 45명이 해당 안내서를 완성하였습니다.
Fabio
회원 가입일: 10/16/14
1,506 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-2, Duarte Fall 2014 UMass Dartmouth, Team 2-2, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G2
4 회원들
안내서 6개 작성하였습니다
댓글 4개
is there a diference between the lte, 3g and wifi versions of the samsung tablet
Josh Robinson - 답글
thanks for the information. i will use it wisely.
Adelle Bradley - 답글
Battery changed, works fine !
Thank you for the tuto :-)
Sharky Billy - 답글
Great guide thank you.
My cover is not flush, even though I carefully attached the top first then downwards - I'm just clumsy I guess.
George Cooke - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 54,402
